Equipment Canon EF 28-105mm f/3.5-4.5 II USM?
Discussion in 'Photography, Art & Design' started by FragileSocks, 17 Apr 2008.
  1. FragileSocks
    FragileSocks What's a Dremel?
    25 Nov 2007
    Just looking into maybe getting this lens. I have heard many good reports about it, and very few bad (does not always focus correctly, sometimes gets confused). I know its not as good as an L lens, but they are way out of my budget.
    The reviews I have read are quite old (early 2007), so is it still one of the best value lenses in todays £150 range for a walk about zoom lens or should I be looking at something else?
    I am not too bothered about wide angle at the moment, but will most likely get a nifty fifty for that later.
    Thanks in advance for any help you can give me.
  2. RTT
    RTT #parp
    12 Mar 2001
    A few people here have them, myself included. Great lens, nuff said
  3. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    The lens is great, but I'm not sure you're quite aware of "walkaround" and "wide angle". First of all, a nifty 50 is exactly that - 50mm flat. That's not wide angle at all - in fact, on a 300D-350D-400D-450D-30D-40D (crop bodies, all) that's equivalent to about 80mm.
    A 28-105 is a good zoom range and this lens in particular is a great performer, but you should know that 28mm on a crop body is really equivalent to 45mm (almost that nifty 50) on any of the above cameras - not exactly what one would consider wide at all.
    To be honest, I think you might find yourself a bit too narrow for a terrific walkaround lens, but that's just me. Your mileage, as always, may vary ;)
  4. FragileSocks
    25 Nov 2007
    Thanks Da Dego. That is very helpful, regarding the wide angle lens.
    Getting ahead of myself here a little but can you recommend a wide angle lens, and would I benefit much from a wide angle converter for a nifty or the 28-105, rather than paying more for a wide angle specific lens?
  5. RTT
    RTT #parp
    12 Mar 2001
    Take a look at the Sigma 10-20 or the Canon EF-S 10-22 for wide.
  6. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Cracking lens for the money, yeah it's not L class, but you already know that.
    I have one myself and really like it, auto focus is good on all focus points even in poor light, obviously the central focus point performs best (more a camera thing than lens though).
    It performs best around the 50mm range @ F8, it softens a little wide open but not by much and performs well at the long end.
    Obviously being F3.5/4.5 low light conditions pose an issue, but as you will be aware an extra couple of stops will cost more than an extra £100.
    Best bang for buck in the Canon line-up excluding the L's
  7. olv
    olv he's so bright
    23 Sep 2002
    To add a different side to the discussion I have one and i hate it. i never use it anymore because it's slow (aperture wise), not that sharp and lacks contrast. overall, it just requires too much PP work to get anything that is satisfying to me. combined with the fact that 28mm is not really wide enough on a cropped body as a walkabout lens it really doesn't have a lot going for it. on the plus it's pretty cheap and not that badly built and the autofocus is quiet and fairly fast.
  8. Vers
    Vers ...
    23 Oct 2007
    FWIW: http://www.fredmiranda.com/reviews/showproduct.php?product=206&sort=7&cat=27&page=2
    It's a decent lens for the money, but there will be instances where 28mm just won't be wide enough and where the slow(er) aperture will take its toll...
    As for your plans of picking up a 50mm for a wide angle (?) thats not a good one. The nifty is a good lens...its just by no means a substitute for wide angle.
    In the end it may be a good idea to save your pennies up a little while longer and get a better lens (eg. Sigma 17-70, Tamron 17-50) Hell, you will get better images from the 18-55 IS.
