Canon EOS 400D, officially.
Discussion in 'Photography, Art & Design' started by Tomm, 24 Aug 2006.
  1. Pookeyhead
    30 Jan 2004
    Rubbish. While this CAN be the case with some sensors at high ISO speeds, there's no reason to suggest that a higher density will increase noise. It depends on the sensitivity of the elements that make up the sensor.
    Like I said.. All things being equal... I can't imagine Canon just increasing resolution at the expense of sensitivity as a marketing ploy. Digital cameras have been around long enough now - people aren't as easily wowed by megapixel figures, and people will more than ever expect to see results before they buy. They increased density from the 300D to the 350D and also improved noise levels.
    I'd be very surprised if Canon have merely tried to hoodwink us with a resolution figure. After all, they're in a very competative arena right now, and to release a dog at this stage would cost them dearly.
  2. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    tbh resolution makes little difference going from 8 to 10. i barely notice the 6 to 8MP increase after upgrading from 300d to 30d.
    i am somewhat concerned about what will come with the 40D, since they seemed to have levelled off the difference between budget and semipro with this new cam. but then i think so myself - who cares? i have a sweet cam i'm happy with.
    (flickr updates btw peeps, i'm on holiday...)
  3. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
    want to take bets?
    There's a point beyond which for a given size sensor cramming more Mp onto it results in more noise & we're already there with current technology & the APS-C sized sensor (witness Nikon D200 & Sony A100).
    Ever thought why Canon went to 8Mp first rather than 10 straight away?
  4. Fod
    26 Aug 2004
    ...to avoid cannibalising 5D sales?
    the 350D has less noise than the 300D.
  5. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    Worst case,the 10mp has equally noise as the 8mp.. I don't think they would make a camera with more noise then it's prequal. And what about the 16mp camera's on 1.3 ?
  6. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    A 1.3 is bigger than a 1.6. Therefore fitting 18.75% more pixels onto the screen.
    I'm sure the manufacturing proccess is different too as the size doesn't completly make up for it.
  7. Pookeyhead
    30 Jan 2004
    As I said in my earlier post, it depends onthe sensitivity of the elements. Make no changes to the technology, and just cram more in there, then yes, as the overall sensitivity of teh chip is lower. I suggest that's not the case with the 400D however.
  8. Hwulex
    Hwulex What's a Dremel?
    1 Feb 2002
    Nikon, maybe. They still seem quite fond of paper releases. Canon, on the other hand, are getting rather good at their accouncing/releasing. The camera is already in mass production at time of announcement with shop releases happening just weeks later.
  9. Lovah
    10 Jul 2002
    It should be available halfway september.
  10. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    Review http://www.dpreview.com/articles/canoneos400d/ :)
    The larger buffer and sensor clean would be my favourite features as the 300D only really copes with 3 RAW shots before you have to stop and let the buffer empty.
    10 on the 400D would be ideal!
  11. atanum141
    22 Jul 2004
    would that mean that the 350D's price will fall more?
  12. coorz
    coorz Miffed
    25 Apr 2003
  13. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    I have an option of a second-hand 20D, or possible one of these 400Ds for my birthday. Which do you reckon I should go for?
  14. Lovah
    10 Jul 2002
    woohooow reviews! The noise increase is so slightly minimal and not noticable in real life use so thats just fantastic! Getting this from the moment I get back from my holiday (end of this month).
    Since I can't decide on a lens, so I'm getting the kitlens with a 50mm prime. I'll see later on wich lens I'm getting...
  15. Fod
    26 Aug 2004
    20d without a moment's hesitation.
  16. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    Seconded.
    Basically you get loads more features, better AF, better noise, more robust body, MUCH better size etc. The only things you'd lose would be 2 MP (inconsequential IMO, especially with the kit lens) and the sensor cleaning (which probably doesn't really work).
    P.S. Lovah - the 50mm f/1.8 prime rocks. I got one today and I just love the quality. I did some tests between the kit lens and it really amazed me - really shows you what's possible. I can't afford to be a lens snob though :-(
  17. RTT
    RTT #parp
    12 Mar 2001
    Interesting, I was kinda waiting for someone to say what I thought about saying. Considering I sometimes find it tough to shift dust & dirt with a pretty good rocket blower, I saw the video about the self cleaning thing I was left feeling a bit... ":eyebrow:"
    edit: seconding the 50mm f/1.8 love :D
    edit 2: agreeing with Tomm on 20d vs 400d
    edit 3: i like ending on number 3
  18. coorz
    coorz Miffed
    25 Apr 2003
    Lovah checkout the Dutch 400D thread.
    btw just got back from a week holiday in 'De Haan' :cooldude:
  19. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    This whole sensor cleaning thing seems like a bit of a gimmick to me. It's not removing the dust from the body so it's still going to be in there.
    My next body will be something in the 30D range. I can't handle the size of the 350D/400D and I'm after something with a more robust feel.
  20. Fod
    26 Aug 2004
    no, it DOES remove dust. it has an ultrasonic wave vibration thingy just like every other dust cleaning solution on DSLRs out there right now.
    it's just that in addition to that, if there IS any dust out there that will only be removed with a sensor swab or something similar, you can have it remove the dust automatically in cam.
