Displays Can't Access BIOS?
Discussion in 'Hardware' started by AoE, 2 Dec 2011.
  1. AoE
    AoE What's a Dremel?
    4 Oct 2011
    Ok so I done a clean install windows 7 64bit via usb dvd drive, I'd set the mode to AHCI prior to installing windows. I had changed the boot order for dvd drive to boot 1st. Now I have installed windows and it's working perfectly and I removed the drive, and windows still starts perfectly.
    But now I want to go back and change the BIOS boot order and on the initial boot screen I press DEL for BIOS setup and it says "Please wait" on something like that and simple seems to stall or doesn't access it quickly, should I wait and see what happens or is there an easy when to fix this issue?
  2. AoE
    4 Oct 2011
    found it out reason close thread please
  3. GoodBytes
    20 Jan 2007
    Please explain your findings. In the case someone else sees this post. Be helpful, be nice. :)
  4. AoE
    4 Oct 2011
    Hi basically I didnt wait to see all the ide drives detected on bootup screen, then I press DEL for setup and it went to bland screen.....few seconds later BIOS. Hope this helps someone
  5. GoodBytes
    20 Jan 2007
    Thanks
