Cooling Can't decide so asking here
Discussion in 'Hardware' started by Coloredtoad, 8 May 2011.
  1. Coloredtoad
    Coloredtoad What's a Dremel?
    5 May 2011
    Hi all, been bashing my head against the wall trying to figure this out so just gonna ask and hope for some help:wallbash:. What is the best 120mm x 120mm x25mm fan that i will be able to control the speed using Lamptron FC2 controller. Iv'e seen some from Silver Stone, Thermaltake,Scythe and Antrc just not sure which one to go with :(
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Depends what case you got.
    If you can accommodate the anti-vibration (no screw shroud on this fan in other words!) attachments of the Be Quiet! Silentwings USC then that 120mm fan works really well with the Lamptron from personal experience. I can warn you away from Akasa Apache fans as that does not play nice with the Lamptron, at low voltages the fan cuts out completely where as the Be Quiet! needs very little v to get spinning.
  3. ShakeyJake
    ShakeyJake My name is actually 'Jack'.
    5 May 2009
    I'm a big supported of the Sharkoon Golf Balls. I've got two of the 1000s, a 2000 and 2 of the SE fans. Brilliant, all of them.
    PS - Writing about fans is hard. I almost wrote 'I'm a massive fan of the....' and 'Fantastic, all of them' and even 'writing about fans sucks' all totally accidentally.
  4. Parge
    16 Jul 2010
    The best fan I've ever used, bar none, is the Akasa Apaches. Silent, powerful, and PWM.
  5. murraynt
    murraynt Modder
    6 Jun 2009
    The scythe gentle typhoons are pretty good. Aria have AP fan at half price ATM making them only 6.50 each. They are slightly louder than the other fans mentioned but the fan controller should fix that.
  6. Blogins
    3 Aug 2010
    With the dial right down on the Lamptron the Akasa Apache just emits a buzzing noise because it's not getting enough voltage to start. The Be Quiet! fan can start at this low voltage and has variable speed right to the dial set to 11.
  7. Coloredtoad
    5 May 2011
    I ended up going with the gentle Typhoon Ap15's. Seems everyone rave's about them so I'll give em a go.
