Windows Can't extend taskbar to second monitor in Windows 7 :/
Discussion in 'Software' started by smc8788, 12 May 2010.
  1. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Sorry if this seems like a stupid question, but this is the first time I've set up multiple displays on Windows 7.
    Is there a way to extend the taskbar onto the second monitor, preferably showing the windows I have open on that monitor? I get that you probably can't do that natively in Windows, but is there any third party programs that will do this?
  2. merple
    merple What's a Dremel?
    18 Dec 2007
    Ultramon is usually the most common program for doing this.
    I think displayfusion might have been updated to support W7 better though.
    thehippoz likes this.
  3. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    i use displayfusion - the free version doesnt do the extended taskbar, but you can get a 1month trial of the pro version. even then its only 16 quid (worth it imho).
  4. wyx087
    15 Aug 2007
    Windows (or Mac's top menu bar for that matter) doesn't do extend-taskbar-to-other-monitors.
    UltraMon was the one i used during XP and Vista days. but i've given my secondary to my parents, so not sure about win7 compatibility.
  5. jonni3
    jonni3 What's a Dremel?
    17 Mar 2010
    Ultramon works fine in Windows 7 64, extend the task bar & show's the windows you have open ... Even does the auto hide as well.
  6. dullonien
    dullonien Master of the unfinished.
    22 Dec 2005
    Nothing I've tried quite fully supports win7. You can get an extended taskbar that looks quite good, although the displayfusion one I just installed now is not quite tall enough. Another feature that's missing is the full thumbnail previews. They show a preview, but the media player one misses the player controls and the ie one doesn't show all tabs. Multiple instances of the same program aren't grouped together either.
    So all in all, not quite sure if it's worth it anymore. The Win7 taskbar is so much better than the older Visa or XP ones, it makes it almost impossible to fill, so no need for the extra space as before.
    I'll just give ultramon another go and report back. Ultramon used to be my program of choice, but the releases I've tried on Win7 hasn't been up to the usual high standards set on XP and Vista. Microsoft really has managed to make it difficult for these programs.
    No idea why Microsoft doesn't support a multi monitor taskbar as standard, would make sense. I'd love one where it's actually a propperly stretched out tasbar, with the clock and notification area on the second monitor.
    Edit: just tried the latest version of Ultramon. It suffers the same problem as DisplayFusion, that it's not quite tall enough (I do have my taskbar at the top though). Ultramon doesn't appear to support thumbnail previews either, and it also doesn't group similar programs.
  7. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Yeah, for all the good features they added in Windows 7 they could have added better support for multiple monitor setups.
    Anyway, I tried out the free trials of both UM and DF, but I preferred DF and it seemed to do what I needed to do, plus it's cheaper as well.
  8. GoodBytes
    20 Jan 2007
  9. saspro
    saspro IT monkey
    23 Apr 2009
    IIRC you can do this in the nvidia drivers. I think it's called span monitors.
  10. el2k
    el2k Modder
    18 Jan 2010
    I think i bought Ultramon around 2 years ago? It's one hell of a program for around $30 i think...
    Definitely worth the money in my opinion if you plan on having more than one monitor for time to come...
  11. Matarsak
    Matarsak What's a Dremel?
    26 Jan 2010
    Another vote for Ultramon here.
  12. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    Displayfusion works well ;)
  13. deadlyavenger
    deadlyavenger What's a Dremel?
    6 May 2010
    I use DisplayFusion, great piece of software and I like the ability it offers of having different background images on each monitor.
  14. Danny
    Danny What's a Dremel?
    4 May 2010
    Using displayfusion here to. :D
  15. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    When I made my dual wallpaper I screen capped the current taskbar and extended it across the bottom of the 2nd monitor wallpaper to it looks like it flows across both but really it's just part of the image.
  16. Far-a-day
    Far-a-day What's a Dremel?
    21 Mar 2011
    Try Actual Multiple Monitors. You'll get extended taskbar with Start button, System tray, toolbars, clock and support of all Win 7 features on each monitor.
