Electronics Can't figure this diode problem out.
Discussion in 'Modding' started by thordiddy, 31 Jan 2005.
  1. thordiddy
    thordiddy What's a Dremel?
    23 May 2004
    Hey guys I cant figure out this diode problem.
    Using load line analysis, determine the voltage V for a) V1 = 5V and V2 = 0V b) V1 = 5V and V2 = 5V
    thanks
  2. biff
    biff What's a Dremel?
    8 Jan 2004
    Assuming v is the voltage across the resistor and the diodes are ideal silicon diodes, then your answers are:
    a) 4.3V
    b) 4.3V
  3. thordiddy
    23 May 2004
    Thanks a lot.
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Not if you use load line analysis. The forward voltage drop depends on the diode current, see if
    this helps any.
  5. biff
    8 Jan 2004
    I seem to have overlooked that part, But certainly much more information will need to be provided that just the reverse bias saturation current. I checked out the link you provided and was surprised to read that it this can't be solved, only approximately using code, albeit a pretty good approximation it would seem. I would think graphically should be more than accurate enough.
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    That's for sure. Either the diode graph or some points on it like those given here .
    Data is supposed to be for a 1N4148, from here, and there's a download with info on LLA. I'll pass & use SPICE simulation instead. :naughty:
  7. biff
    8 Jan 2004
    Whats the point of all this anyway? The chart that were to carefully trying to extract exact values from will change from one device to the next, also with temperature, humidity, altitude, phase of the moon... did I miss anything? Any circuit that relies on an exact value of a diode will most certainly be unreliable when taken out of the lab.
