Motherboards cant flash bios asus M5A88-M EVO
Discussion in 'Hardware' started by Harlequin, 7 Feb 2013.
  1. Harlequin
    Harlequin Modder
    4 Jun 2004
    a fiend is trying to fix an issue with his mobo - the board is an asus M5A88-M EVO ; but each time we go to do it , the flash programme says ` no suitable bios` or words like that
    but the latest bios is freshly downloaded :(
    any idea`s?
  2. ferret141
    ferret141 Minimodder
    18 Oct 2010
    Are you trying to flash it through the BIOS?
    Why not create a DOS bootable USB stick and flash it that way? (Let me know if you need instructions)
    Also why are you flashing in the first place? To fix a problem or keeping updated for the sake of it.
  3. Harlequin
    Harlequin Modder
    4 Jun 2004
    fixing a problem (and yes flash through bios)
    1/2 the time the machine is cold started it needs to be unplugged before it`ll boot properly ; bios on it is original and the machine is using an FX chip
  4. matt_lumley
    matt_lumley You're only supposed to...
    28 Apr 2010
    Obvious check I am sure you have checked already but it never harms to check:
    • Correct version of new BIOS from manufacturer (I always forget to get the B3 version for mine for example)
    • File isnt corrupt on your selected upgrade medium
    • Checked for an in winows version?
    • If there is a windows alternative make sure to check clear DMI data and over write previous.
    • Tried leaving it unplugged and without battery for a while to clear all existing data?
    Just the first few that come to my head.
    Matt
    Edit:Clicky for the newest BIOS updates from Asus for that board.
    Also are you going from the previous version or an older one. if you are going from one more than one generation old trying upgrading in sequence.
  5. bulldogjeff
    2 Mar 2010
    Are you using the EZ flash? it should be a doddle because it will do everything for you.
  6. jinq-sea
    15 Oct 2012
    If the BIOS file is on an NTFS disc, EZFlash will see it but won't be able to access it. If you dump it on a USB stick, you should be laughing.
  7. ferret141
    18 Oct 2010
    I typed this in a rush. Feel free to ask me to clarify anything.
    Use either guide to create a DOS-USB stick
    http://www.vistax64.com/tutorials/191416-dos-usb-boot-drive.html
    http://blogs.technet.com/b/csstwpla...create-a-ms-dos-bootable-usb-flash-drive.aspx
    Once you've done that download BUPDATER from ASUS.
    Place it in the root folder of the USB stick.
    Place your new BIOS file in the root folder as well.
    It might be a good idea to rename it. Stick to 8 characters max.
    Restart Pc and restore current BIOS to default settings. Save and exit.
    Boot from your DOS USB. Pressing F8 or F12 at the BIOS screen should bring up the boot device selection screen.
    Boot from flash drive.
    A screen that looks like command prompt should come up.
    First we'll backup the BIOS
    Type in, without quotes, "BUPDATER /oOLDBIOS.ROM"
    BUPDATER will run. At the end it will prompt you to press any key and it will return you to the DOS screen. Now you will have a file saved to your flash drive called "OLDBIOS"
    Next type in "BUPDATER /iNEWBIOS.ROM"
    Where NEWBIOS is whatever you named the file for the BIOS before.
    Follow the prompts and you should be done. If when done and it send you back to the DOS screen then press Ctrl+Alt+Del and it should restart you computer.
    Load defaults in the BIOS once again. Save & exit.
    See if PC is running fine and your problems are fixed.
    This may help
    http://www.youtube.com/watch?v=6vr4y8rUNXA
    EDIT: I didn't realise people had posted while I was typing. Jinq-sea may be right.
