Can't force client to work faster with Q9400
Discussion in 'bit-tech Folding Team' started by Synay, 14 Nov 2009.
  1. Synay
    Synay New Member
    25 Oct 2009
    Ha! I nailed it! I finally made it! Sorry, pardon my excitement but after all those days I made it work on all four cores. This is what I've done:
    1. Downloaded FAH6.22 beta2 SMP mpich client and installed it.
    2. Run install.bat in a command prompt as an administrator.
    3. I replaced main executable with 6.24 smp from Stanford's website.
    4. Started it as normal, which allowed me to input my username and team number.
    5. Waited for it to run. Closed it, created a shortcut to the desktop.
    6. Edited shortcut to add a "-smp 4" flag and run it again.
    And voila!
    And as you said, I was missing out on quite a lot of points. Thank you so much everybody, if it wasn't for you I'd be still folding on one core :thumb:
  2. dark_avenger
    dark_avenger Well-Known Member
    9 Jul 2008
    Good to hear, fold on :thumb:
  3. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    Well done - it can be quite a struggle sometimes. :thumb:
  4. Ross.Davis
    Ross.Davis New Member
    4 Aug 2009
    I cannot reconfigure due to IP issues.
    My IP address is 10.119.252.112
    I live in university halls run by Ask4.
    Any guesses?
    Cheers
  5. saspro
    saspro IT monkey
    23 Apr 2009
    Pardon? What was the question? Shouldn't this be a new thread?
    You're running a on a class A address, this is a private address not a public one.
    You probably need a router but my crystal ball is in the workshop at the moment.
  6. Christopher N. Lew
    23 Apr 2009
    LOL
  7. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    i would recommend that you use notfred over the WinSMP your losing up to half the work time been wasted using winSMP, not sure how Synay managed to make notfred error (running it off an USB ??)
    if you both need support i can do it if you wish just get Teamviewer (www.teamviewer.com) and set an time to get it all working it only takes 2-5 mins to do (if vmware player is installed as that needs an reboot)
    my Sig is not working again.....
