Networks Cant get laptop to see wireless network all other PC's do
Discussion in 'Hardware' started by JonDixon, 27 Sep 2007.
  1. JonDixon
    JonDixon Decking is the new modding
    12 Mar 2002
    Anyone know what I may be doing wrong?
    Just got a new laptop (Dell D420) which has built in wireless. Now I know the wireless works as Ive used it at work and on other networks.
    However it just won't see my wireless at home. I have a sky broadband router.
    My home PC and my wifes laptop which are also both Dells had absolutely no problems finding the router.
    Any ideas why it can't see my wireless. I just don't know, when I search for network connections Im finding neighbours etc but not my own (mine is broadcasting).
    So any suggestions? all help appeciated
  2. Arthur2Sheds
    Arthur2Sheds Jackson
    19 May 2003
    Any security enabled on the router?
  3. markjw
    markjw What's a Dremel?
    4 Aug 2007
    possible problem that I have seen before is if the router is on Channel 12 or 13 - some devices only support the USA channel allocation of 1-11 and thus will not see a router on Ch12 or 13.
  4. JonDixon
    12 Mar 2002
    No security on the router that I know of.
    I have changed channel to 13 though so will try 11.
