Displays cant get two monitors going
Discussion in 'Tech Support' started by chrisb2e9, 6 Oct 2012.
  1. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    Hi,
    AMD 6950
    I have a compuer monitor and a TV.
    I installed an SSD.
    re-installed windows vista 64
    Installed the AMD software.
    When I try to extend the desktop I get an error saying the operation is not supported based on the current display configuration.
    I tried re-installing the OS and the AMD drivers. Same issue.
    Anyone know what causes this and what will fix it?
    It worked just fine before I re-installed vista so I don't suspect a hardware issue.
    It will work on one monitor or the other. Just not both at the same time...
  2. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    Can you mirror to both? How are you connecting to each? Resolutions?
  3. chrisb2e9
    18 Jun 2007
    Can't mirror. It's one monitor or the other. Computer monitor is 1080p and tv is only 720.
    Monitor is dvi
    tv is hdmi
    Nothing has changed since I reinstalled vista. It's got to be a driver or something to that effect?
  4. Deders
    Deders Modder
    14 Nov 2010
    are you using the catalyst control panel or the windows screen resolution page to configure it?
  5. chrisb2e9
    18 Jun 2007
    Catalyst control panel.
    How do you use windows to try it?
    Edit,
    never mind I found how to do it in windows. When I tell it to extend the desktop. I hit apply. nothing happens. it asks me to keep settings. I hit yes. nothing changes.
  6. Deders
    Deders Modder
    14 Nov 2010
    Right click on the desktop and select screen resolution, the rest should be self explanatory. I've found I've had to use this way instead of through the Nvidia cpl in the past.
  7. chrisb2e9
    18 Jun 2007
    Looking at vista forums its suggested that windows isn't detecting the second monitor. But I can select it in catalyst control panel and move the display to it.
    I'm really stumped...
  8. Deders
    Deders Modder
    14 Nov 2010
    There is a way to force detection somewhere
  9. chrisb2e9
    18 Jun 2007
    Fixed.
    I unplugged the hdmi that went to the second monitor(computer is off at thsi point) changed the dvi port for the primary monitor from the bottom one to the top on the video card.
    turned computer on.
    regular monitor is working fine. plugged in hdmi cable and boom. second monitor comes to life.
    Odd but whatever!
  10. chrisb2e9
    18 Jun 2007
    Also, the second monitor is set to 1080i
    which it physically doesn't support, but it's working?
    Ok. I'll take a win.
