Cant get USB 2.0 to work
Discussion in 'Tech Support' started by AcidJiles, 12 Mar 2008.
  1. AcidJiles
    AcidJiles Minimodder
    19 Jun 2006
    I have Windows XP SP1a, on an MSI K8N Diamond motherboard with the latest drivers installed for the motherboard (Nvidia). I have had this problem through several installs of windows and the motherboard drivers. It just never seems to enable USB 2.0. Would like to enable USB 2.0 as I have some devices that need it to work. Any further information please ask and any help you can provide would we most useful. thx
  2. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Install Service Pack 2. That should get you going.
  3. AcidJiles
    19 Jun 2006
    no way to get it without sp2. I dont want it if I can help it.
  4. badders
    4 Dec 2007
    Any Particular reason why not?
  5. culley
    culley What's a Dremel?
    12 Jul 2006
    Why!!! it fixes a hell of a lot of things, and i wouldn't have thought you could get XP without SP2 lol
  6. AcidJiles
    19 Jun 2006
    after sp2 causing blue screens on installs of windows al least 4 times on different systems im not hugely keen on it apart from annoying windows defender aswell.
  7. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    Wow, I much prefer having SP2 for everything. As for Defender, etc., you can turn that off and change the preferences so it doesn't "remind you" in the system tray.
  8. cmberry20
    cmberry20 Mad Scientist
    16 Jul 2007
    XP SP2 is pretty much the norm nowadays (in fact I dont know anyone not using it). There is no reason not to use it, as all bugs & problems have been very much eradicated now.
    Its kinda like saying - "I don't trust cars, because they tend to crash into walls & trees & stuff"
    If SP2 was so unreliable I think most XP uses would be using Vista by now.
  9. cmberry20
    16 Jul 2007
    Defender doesnt come with XP SP2. You have to install seperately. And, if you dont want it - dont install it!
  10. Yotta
    Yotta Minimodder
    10 Mar 2008
    That's right, SP2 doesn't install windows defender. Maybe you're thinking of security centre? Which is simple to disable through services.msc.
    I've installed SP2 many times on many different machines, never seen it cause blue screens. I've got several machines running SP2 myself and they're all rock solid. There was several recommendations when installing SP2, one of which was to make sure the system was clean of spyware before starting.
  11. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    Does Windoes even detect the EHCI(s) on your board?
    I assume USB is enabled in the BIOS, is there a setting somewhere for USB 2.0, enhanced usb, or something like that?
