Cant install chipset drivers for Z370 chipset
Discussion in 'Software' started by kuroidoragon, 22 Feb 2018.
  1. kuroidoragon
    kuroidoragon Member
    14 Oct 2012
    I am not sure exactly which section should be in but will try here first apologies if I am wrong
    I have a Asus TUF Z370 gaming pro motherboard & when it comes to installing the chipset drivers from the asus site I get a fatal error during installation image is attached of the error
    why is this ?
    how can I fix & get the latest version of the drivers installed ?
    I contacted scan.co.uk who I got the board from they cant help they said the error is to vague & specific & said to contact asus which I have done I am waiting on a reply but wanted to ask here also to see if i can get a quicker reply & fix
  2. RedFlames
    23 Apr 2009
    Have you tried the drivers on Intel's site?
    Also any pending restarts? The install might be failling because windows is already trying to install a version of the driver in the bg [which it has a habit of doing, esp if it's a fresh install].
  3. kuroidoragon
    kuroidoragon Member
    14 Oct 2012
    not sure If I have tried the ones from the intel site do you have a exact link so I can try & be sure ?
    no pending restarts
    if by fresh install you mean a fresh install of windows then no still the installation from the upgrade ages ago when they was offering windows 10 for free at the begining
  4. TheMadDutchDude
    23 Aug 2013
    You most likely need a fresh install...
  5. kuroidoragon
    kuroidoragon Member
    14 Oct 2012
    come from i think windows 8 was a free upgrade from that so I don't have a windows 10 disc as it was the free upgrade but I am currently trying to make a bootable usb memory stick of windows 10 so will try a fresh install if i don't get a reply soon
    but I wouldn't mind a exact link to the most up to date chipset drivers for my board from the intel site itself as suggested by redflames above I have looked on the intel site but its vague & hard to understand or find anything on there for me
    and also would like to know if someone can tell me how to check what ones are currently installed
  6. TheMadDutchDude
    23 Aug 2013
    You don't need to worry about getting them from Intel. The one on ASUS' site is the same thing.
  7. kuroidoragon
    kuroidoragon Member
    14 Oct 2012
    ahh ok i will carry on with this windows 10 on a usb stick thing for a fresh install hopefully i get it right & not ***k it up
  8. TheMadDutchDude
    23 Aug 2013
    Just follow the steps, man. It couldn't be easier. :)
  9. kuroidoragon
    kuroidoragon Member
    14 Oct 2012
    Back did a proper full format & fresh install of windows 10 now & all drivers including the chipset went in properly this time ....thanks for the suggestion madDutch
  10. TheMadDutchDude
    23 Aug 2013
    Told ya. It’s never smooth transferring from an old system to a new one. ;)
  11. kuroidoragon
    kuroidoragon Member
    14 Oct 2012
    I did encounter a problem along the way which I fixed after a quick panic & a google search on my phone about when drives are of gpt partition or something which I fixed by typing in some commands in a black window win key+F10 while on the windows setup menus quite please with myself I worked that one out quite quickly
    TheMadDutchDude likes this.
