Networks cant make network secure?
Discussion in 'Hardware' started by pillow, 1 Jan 2005.
  1. pillow
    pillow What's a Dremel?
    16 Aug 2004
    i cant make my wireless network secure, i try using wep but then when i try to connect to it from my laptop it wont connect. i have tried wpa too. i have a DI-624 rev. c router( with latest firmware), DWL-G520 for my dads comp, DWL-G650 for my sisters laptop,and i have sbc dsl. shoudl i try setting up the wep on one of the computers that is wireless or try again on my comp, which is wired?
  2. Ibbz
    Ibbz What's a Dremel?
    3 Jan 2005
    Mac Filtering
    Why don't you just enable Mac filtering? Wep is worthless anyways to easy to be cracked.
  3. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    Make sure you have the network key correct, my wireless network is encrypted using WEP and I have to admit it is not uncommon for the computers not to be able to connect to the router, even if it can see it.
    Also make sure that the router is set up in the right mode - i.e. B and/or G.
  4. craig
    craig What's a Dremel?
    6 Mar 2002
    i have a di-624+ and a gwl650+ for my laptop with wep enabled and mac filters. you shud be able to get it to work no problem. make sure you are typing the wep key correctly and that you have selected the right key number. I had loads of problems with my di-624 when i got it, the dlink firmware is the greatest on these routers. Id update my firmware again but i dont want to risk something else not workin. Ive heard that the USR firmware is good though
  5. pillow
    16 Aug 2004
    i have tried mac and i have the latest firmwire for the router. i will try again this weekend
  6. Ibbz
    3 Jan 2005
    Make sure when you have your mac filtering enabled that you have Allow only these computers accesss instead of block computers with these addresses. Know what i mean? You may be blocking yourself out of the network.
