Modding Car Audio in...
Discussion in 'Modding' started by ShockSonic, 10 Oct 2004.
  1. ShockSonic
    ShockSonic What's a Dremel?
    10 Oct 2004
    Is it possible to mount car audio speakers in a pc case and to have them work like regular speakers? On a second note... would mounting Subwoofers (with rubber mounts of course) send too much vibration through the system and cause problems?
  2. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    I would be more worried about the magnetism from those speakers than the vibration.
  3. Caj Darkmoon
    Caj Darkmoon What's a Dremel?
    1 Aug 2004
    Yeah, that's like creating a box made to destroy computers.
  4. ShockSonic
    10 Oct 2004
    Hmm... Any way it could be done?
    If it can, i have a sweet ass design I could be working on..........
    Is there any hope?
  5. Rekarp
    Rekarp What's a Dremel?
    7 Mar 2004
    suround the magnets on the speaker with brass. :idea:
  6. ShockSonic
    10 Oct 2004
    Is it just the Sub that I cannot have, or all car audio speakers?
  7. Ben '71 1200
    Ben '71 1200 What's a Dremel?
    16 Aug 2004
    they all have big magnets in them.
    To be honest, you *should* be fine as long as it's all shielded properly, but I wouldn't want to risk it.
    You'd need an amp to power the speakers to make them work as well.
  8. penski
    penski BodMod
    29 Aug 2002
    It would sound bloody awful too.
    *n
  9. SoylentGreen
    SoylentGreen What's a Dremel?
    27 Jun 2004
    hey, i want a machine that destroys computers. although i do have a sledge hammer.
    NEW MOD: giant magnets hidden inside a suitcase! i could just walk around and kill computers. they would call me SOYLENT GREEN, DESTROYER OF FILES.
  10. Rekarp
    7 Mar 2004
    yah penski is right. You would have to many openings in you case.if you had one it would be ok. Here are some sites if you want to build your own.
    Link
    Link
    edit/ aluminum might work
  11. Caj Darkmoon
    1 Aug 2004
    Constant large scale vibrations of all the computer components? No thanks.
  12. ShockSonic
    10 Oct 2004
    Thanks for all the helpfull hints.
    I have seen computer audio speakers embedded inside a case. What are the maximum sizes/stats for all of these?
  13. dead_man
    dead_man Confucious say: WTF???
    4 May 2004
    running car speaker in ur case will distort it massivly, especaily alluminium
  14. Xgamer
    Xgamer What's a Dremel?
    29 Oct 2003
    Just mount the speakers in a seperate box.
  15. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    "xgamer" has the right idea, but i would say just go and buy a decent pair of copmputer speakers (i know that you have some car speakers lying around thats why you asked) you may not want to spend the money but it is best for teh computer and it's parts,
    *side not* also the heat from the componets would hinder cooling of the system, so again i would recomend just getting real computer speakers
