Electronics Car door lock relay
Discussion in 'Modding' started by Stealthrt, 9 Oct 2008.
  1. Stealthrt
    Stealthrt What's a Dremel?
    16 May 2002
    Hey all i am trying to figure out the best way to hook up one of the digital out pins on a ATmega168 chip to my car's door lock/unlock buttons without frying the board...
    What all would be needed in order for the output pin to activate the relay needed for the wires to act as if the user was pushing the car's lock/unlock buttons?
    I know i would need a 12v line to the relay but what else am i missing that i am not thinking about?
    David
  2. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Have a look at the Haynes motor manual for you car, It will show you which pins you will need on the central locking ecu.
    As far as I know there available world wide.
  3. Stealthrt
    16 May 2002
    Thank you for your reply AJB2K3 :)
    Hum maybe i should ask the question another way...
    In order for the door to lock and unlock.. how much voltage is used? When the user pushes the button to ether lock or unlock the door... how much voltage does that wire get in order to start the mechanism? I take it 12v since it uses a 12v relay on both doors? Do i just spice in the between the door lock button wire and the relay itself?
    Here is my schematic of my door locks..
    Sorry for the noob question :)
    David
  4. AJB2K3
    12 Dec 2005
    Pass, cant see the path atm, will have another look tommorow.
  5. Stealthrt
    16 May 2002
    The way i look at this is after going through the relay i have on the board i would then hook the wire up to the BR-L wire (Unlock) or the BR-W wire (lock) but i am not sure if thats where i would need to splice in order for it to work.... or what voltage is needed to trigger the Door Lock Power Relay.
    David
  6. ZERODESIGN
    ZERODESIGN What's a Dremel?
    7 May 2008
    Get your multi meter out and connect it the the lock release solenoid. It should be around 12-13 volts to a ground, im not sure of what amperage you will need as it will vary from one solenoid to another
  7. Stealthrt
    16 May 2002
    Yeah im sure it is within the 12v-14v range. I just need to find out where i need to hook up the wire in order for it to "act" as if i pushes the button for either lock or unlock.
    David
  8. thim83
    thim83 What's a Dremel?
    17 Oct 2008
    Just check it with a tester
