Motors Car subwoofer question
Discussion in 'General' started by dork, 27 Jun 2005.
  1. dork
    dork What's a Dremel?
    12 Jul 2002
    anyone know a good sub/amp to get for a truck? Getting a 2001 ford ranger and want to put a sub in the extended cab. I have to be able to get it from bestbuy though just because they are the only place to install them in town. Anyone know?
  2. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    Go to crutchfield.com, and buy what you want there. they also sell service cards so you can get your stuff installed at best buy.
  3. dork
    12 Jul 2002
  4. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    problems with links.
  5. dork
    12 Jul 2002
    thanks- links fixed. I bought both of those, i can still return them, i just want to make sure the amp will power it
  6. dirtbiker
    dirtbiker What's a Dremel?
    24 Dec 2003
    Should be fine...
    One thing I have noticed is that the Infinity amp seems to need a 6v input voltage. Do you know where you can find this in your truck?
  7. dork
    12 Jul 2002
    no clue, im a complete nub. Im taking it to bestbuy, all i know is i have to run back to circuit city and get these--
    http://www.circuitcity.com/ssm/Tsun.../sem/rpsm/oid/71670/rpem/ccd/productDetail.do
    or something like that? Thats all i know...lol . i need to buy some cables whatever their called. But i hope this system sounds good =). got the amp for so cheap i had to buy it
    better yet i better get some 800w wires lol
    http://www.bestbuy.com/site/olspage...CategoryId=pcmcat30100050007&id=1051384110665
    other than that that sub and amp will work good together??
