Scratch Build – In Progress carboFlow - headphones/case (13.11)
Discussion in 'Project Logs' started by WolfandAngel, 20 Mar 2011.
  1. WolfandAngel
    WolfandAngel Got fins?
    2 Dec 2008
    Introduction
    Hello I'm WolfandAngel also know as wolfie. I started modding a few years ago with a very basic mod. As I got more experienced I tried more difficult and complex mod, with my latest mod Sidewinder. I am 18 and still go to school. I've got my exams soon so there might be some long gapes in between updates.
    This is my fifth project and it was it will develop a bit like the Sidewinder. If you've read the log you'll know that I started the mod with a render of the mod. Well this project will be totally different I was trying to make renders and sketch up but the way I want to make the form it's not within my ability. If you want to know a bit about the planning look here. One very big thing I will continue from Sidewinder is the "prototype" thing. Because I have virtually no model only ideas. So I plan on making a few prototype to see what works and what doesn't.
    This is gonna be a small case so I will use a ITX board and a small PSU (SFX12V) as case material I will use carbon fabric. The form is supposed to look a bit like a fish or shark with some sharp edges in it.
    Most recent picture/video
    Index
    Small update and video(30.03)
    Making Carbon Fiber Door
    Video guide second door
    middle part
    80% complete
    cabling
    USA/PSYKO headphones
    headphones/case
    Sponsor
    Hardware
    SilverStone Strider SST-ST45SF, 450W SFX12V
    Gigabyte GA-H55N-USB3, H55
    wolfie
  2. WolfandAngel
    2 Dec 2008
    I'm amazed at how small ITX boards are
    A size comparison
    My temporary motherboard tray
    I'm planning to make a mold for the carbon
    wolfie
  3. MrNitro
    MrNitro Performance Enthusiast =)
    26 Jun 2010
    Did I heard it right? CF?
    Hell yeah!
  4. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    interested to see, how will this come out :thumb: good luck
  5. IcyAero
    IcyAero What's a Dremel?
    4 Aug 2010
    I just love mini-ITX builds, designing one myself at the moment as well for future. :)
    Also, if the PSU you're going to use for this project has a slow fan (doesn't require an exuberant airflow and stays cool), I'd recommend cutting some holes on the motherboard tray and let it take air from inside the case and at the same time sparing you from having to add any extra holes on the exterior of the case. :)
    Keep on rocking on the build, I'll be watching! :rock:
  6. WolfandAngel
    2 Dec 2008
    Hi I'm happy to announce andthank my new sponsor Psyko Audio Labs
    and I also want to thank crucial
    wolfie
  7. 0rbibital
    0rbibital What's a Dremel? Stop asking that!!
    28 Feb 2010
    CF mod Cheesecake
  8. KidMod-Southpaw
    28 Sep 2010
    Mmmm, carbon fibre... I can't wait to see more wolfie!
  9. Silent_Raider
    Silent_Raider What's a Dremel?
    20 Aug 2010
    Yay for CF!! Looking forward to seeing more.
  10. WolfandAngel
    2 Dec 2008
    Thanks guys:thumb::thumb:
    Thanks for the tip and good luck.
    I've been working on the other side for the last days but I can get the basic shape but not the way I want it so I will probably redo this side. Anyway let me know what you think.
    Link
    wolfie
  11. WolfandAngel
    2 Dec 2008
    Oh can you please tell me if you want me to put in music or just leave it blank.
    After my latest failed mold I made a new one, that I'm very happy with. My idea was to make "mini" fins that are wavy compared to the sidewinder ones and probably only two on each side instead down the middle.
    A lot of filling,sanding and a few layers of paint this is what I got:
    The paint is so that after the body filler was sanded the epoxy couldn't get through the mold wax.I also applied some "Film release agent" it's kind of like a liquid foil that should help releasing the mold from the carbon body.
    wolfie
  12. Waynio
    Waynio Relaxing
    20 Aug 2009
    Ohhh kickass :rock::jawdrop: I'll be tuned in along the way WolfandAngel :D:thumb:.
  13. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    carbon fiber!!!!!!
    i love it!!!!
  14. disturbed13
    28 Nov 2008
    carbon fiber!!!!!!
    i love it!!!!
  15. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    / follow :D!
    Front row seats Cheesecake :D
  16. 0rbibital
    28 Feb 2010
    can't wait to see that door finished
  17. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    It looks looks like something good is comnig out :) Keep going ;)
  18. matiss
    matiss Minimodder
    24 Jun 2010
    Can´t wait to see what happens next. subbed
    @WolfandAngel Grüße nach Deutschland ;)
  19. Cheapskate
    13 May 2007
    Cool! I can't wait to see what you come up with.
    BTW kids, the cheapskate equivalent of CF is old urethane lacquer and dryer lint.:thumb:
  20. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Mmmm... Carbon fiber! Is it bad to want to lick it? :blush:
