Modding Carbon fiber
Discussion in 'Modding' started by Yumadil, 7 Dec 2004.
  1. Yumadil
    Yumadil New Member
    17 Jul 2004
    Where can i find carbon fiber kits for sale in the US. I have a case idea that may work well with it.
    Thanks
  2. kaotic504
    kaotic504 New Member
    20 Jul 2004
    i know you can get them off of ebay. there was a site that i saw that sold raw materials like that, but i forgot where, i'll reply when i find the address.
  3. infernis
    infernis New Member
    5 Jan 2003
  4. Infraggable Krunk
    Infraggable Krunk New Member
    7 Mar 2004
  5. Jordanis3r
    Jordanis3r Jigsaw Master
    8 Jan 2002
  6. Infraggable Krunk
    7 Mar 2004
    um did you see the molds he had to make ??
    and no disrespect to mashie, but that CF wasnt entirely smooth. If you want perfectly smooth Carbon fiber you need a super smooth mold along with a good technique (vacum injection is the preffered method)
    Im planning on buying large sheets of glass and then making a large sheet and cutting it to size
  7. Jordanis3r
    8 Jan 2002
    well yes - you can go the vac route - which I have also tried whilst making kiteboards a while ago - even then i found that i had to do alot of handiwork afterwards to get a completely smooth surface - as long as you are heavy handed with the resin you can always sand the resin layer flat and polish that :)
    (which is the way I did it:))
  8. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    I'm sorry but I've seen the results and they are perfectly smooth, vacume forming is expensive anyway :)
  9. jswilson64
    jswilson64 New Member
    29 Aug 2003
  10. Infraggable Krunk
    7 Mar 2004
    Riiiiiiiiiiiiiiiiiiiiiiiiiiight
    like i said no disrespect, but its a BTCH to try to get an absolute perfect sheet without vacumm molding
    I had 20 feet of this stuff and was about to drop 50 bucks to buy two large panes of glass to get a super flat sheet, but in the end i paid my friend 30 bucks to laminate 10 feet of it and it turned out decent.
    Ive made 2 small pieces using two pieces of glass and they turned out great, but i cant imagine doing this and getting no airbubles on a piece larger than 2 feet by 2 feet
  11. quadbox
    quadbox New Member
    13 Jan 2005
    i hope anyone knows where shop i can buy this... i need it for my upcoming mod... :D
  12. Nitro_APBT
    Nitro_APBT SpiderModder
    29 Dec 2004
    there are a million places online to buyu CF.
    Google for carbon fiber cloth.
    It's not that hard to work with. Making sheets is pretty easy.
    My technique was this:
    Materials:
    2 pieces of glass thicker the better. Window glass might break when trying to seperate.
    Carbon fiber cloth
    Resin
    4 spacers (I used nuts (as in nuts and bolts) that were 1/8" thick)
    paintbrush (disposable)
    1. Clean the glass
    2. Wax the glass (any auto wax)
    3. Apply a thick layer of resin to the glass
    4. add cloth
    5. add resin
    6. repeat. (I want to say I used 14 layers for 1/8")
    7. add resin to second piece of glass (waxed also)
    8. place ontop of layered cloth/resin with spacers in corners.
    9. Use some type of thin wedge to seperate the glass from the now solid sheet of CF. This is the tricky part, and thin glass will break before the bond is broken. I've done this with fiberglass, and it sucks trying to pull the pieces off.
    for any other shape you have to build some sort of skeleton, or a mold.
    I prefer to build a skeleton for most things. Then cover it with speaker grill cloth pulled tightly. This gives you a good shape to add layers of CF cloth to.
    You will have to sand and polish in the end to get a perfectly smooth surface, but it's alot easier than trying to build perfect molds, etc.
    Also... For any cut edges, use krazy glue, or any type of CA glue to seal them.
  13. Infraggable Krunk
    7 Mar 2004
    can i see some of your end products ??
    also where did you get your CF
    i managed to get mine for 12 bucks of a guy on ebay.. alas hes not selling anymore.
  14. Nitro_APBT
    29 Dec 2004
    LOL, I wish I could show you.
    All of my flat stock parts were for RC cars, and have all been sold, thrashed, or packed away in my garage for quite some time now. The built up (non) parts I've done were actually fiberglass, or fiberglass kevlar mix, and are all in cars covered in vinyl, or carpet. It's funny how guys will put 60 pound subwoofers in a car and want exotic composite enclosures to save weight. :rolleyes:
    I might have a chunk of fiberglass flat stock laying around inside. I'll try to dig it up today.
    edit: sorry, forgot ... I got mine from uscomposites.com, and also from ebay. Every once in a while someone will unload extra that they didn't need for a project or something. I've only gone through a few yards of CF. I used it when I was racing and needed a part that noone else made yet.
