Case Mod - In Progress Carbon Li at the Computex **Tampei**.
Discussion in 'Project Logs' started by Ediejo, 26 Nov 2006.
  1. Ediejo
    Ediejo New Member
    31 Jul 2005
    Some chancing. Al the led’s will be chanced. ;)
    Yes for green ones.
    The much brighter than the purple ones.
    Even with the blitz on the camera you see the well.
    Camera on auto mode. No way.
    That’s better.
    Close up from the feet
    Mhhh some green stars.
    Now white this panel.
    Later white an airbrush like this. Then green looks better than purple. And green is the collor from Point of View and Nvidia. ;)
    See you soon.
  2. chase
    chase New Member
    11 May 2006
    Wooouw!
    Amazing effect from those LEDs there, keep up the great work ;)
  3. Jipa
    5 Feb 2004
    Uuh green ones look even better, because I like green and I think it's the least used color in case modding. :thumb:
  4. marauder16
    marauder16 New Member
    30 Sep 2006
    well liked the purple ones more, but the green ones look great too, and yes the purple wouldn't fit with the logom so the green is better choice in that case ;)
  5. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Ah, now it's starting to come together! Can't wait for so'more updates dude!
  6. jegerjon
    jegerjon New Member
    10 Jan 2007
    amazing you've also got airbrush skillz? omg dude you are sick :O
    Looks wonderful with the green leds, its cool!
  7. Infenro
    Infenro New Member
    7 Oct 2005
    Yea i agree with you i like mods that use non mainstream colours, ive been using red and purple for some time now.
    Nice mod really like how its turning out keep up the good work :rock:
  8. Ediejo
    Ediejo New Member
    31 Jul 2005
    Some hardware chancing The 2 corsair’s power supplies will be chance for 1 Tagan 1100Watt.
  9. GoTaLL
    GoTaLL New Member
    17 May 2005
    damn this looks sweet .. i could use a couple of thoose psu´s too :p
  10. vitriol_drinker
    vitriol_drinker New Member
    21 Nov 2006
    Warning of the molex to sata connectors.
    With those there are some "poor contact" (found in google trad in french we say "Faux contact" if this can help you) and this can kill some hardware. A french tester killed 1 HDD because of this. :wallbash:
  11. Ediejo
    Ediejo New Member
    31 Jul 2005
    @vitriol drinker, thanks for important the info.
  12. Ediejo
    Ediejo New Member
    31 Jul 2005
    Time for an update. Today I started white the carbon for the feet.
    And white this saw wit goes also very well.
    That’s looks better in my eyes white with carbon.
    Also the combination White Carbon and green is oke.
    Making the 45 degrees corners.
    Fit well.
    As I said before it breaks the white.
    Than some glue work to do..
    And waiting a couple of hours to start to fil it.
    Before I can start to fill I must fix the other side also.
    See you soon.
  13. derbaum
    derbaum New Member
    11 Apr 2004
    thats definitly cool. what kind of sawblade did you use for cutting?
    i liked the uv leds a lot more but green is ok 2
  14. Bluefan
    Bluefan test 123
    25 Feb 2005
    A white case and green leds, that's not that common, too bad :D this really looks good.
    The logo of Point Of View looks to have a different shade of green, I think it will look better if the final logo you use will have the same shade of green as your leds.
  15. Ediejo
    Ediejo New Member
    31 Jul 2005
    And fixing the other side white glue.
    Even saw the lower part.
    I must clean the carbon, I know. ;)
    To keep it by one colour. Also chancing the led’s behind the mainboard.
    I lost much light at the back side. So maybe it helps when I kit them with black kit to keep the light at front. ;)
    This one is for derbaum.
    See you soon.
  16. wbdog206
    wbdog206 not me
    15 Jan 2007
    very nice i like the green and white.
    excelint work :thumb:
  17. Jipa
    5 Feb 2004
    Carbon looks so damn sexy people would definitely use it more if it wouldn't make the notorious dust.. And would be more widely available. Great work once again, still looking forward :rock:
    btw this is the first time I see a K8N SLI-diamond after I sold mine... And TBH I'm not wondering why nobody actually bought any of those.
  18. Stievius
    Stievius Industrial Design Student
    12 Nov 2006
    I don't really get exactly what you're gonna do with that kit... Surprise me.
  19. derbaum
    derbaum New Member
    11 Apr 2004
    thx. looks very much like a normal blade for cutting wood. does it produce any cracks in the material ?
  20. Duste
    1 Oct 2006
    The lights seem to look a hell of a lot better with that Carbon Fibre there, or it may just be a higher focus photo, but nevertheless it looks a lot better!
