Graphics card length
Discussion in 'Hardware' started by jeff00z28, 18 Aug 2006.
  1. jeff00z28
    jeff00z28 What's a Dremel?
    30 Jul 2006
    Does the 7900 or 7800gt exceed the length of 7 inches? Just making sure because I wanted to get a 7800 gtx but they are all way too long for my case. Thanx.
  2. [1N0V471V]
    [1N0V471V] What's a Dremel?
    27 Feb 2006
    I'm not at home right now so I couldn't tell you, but my 7900GT is shorter than my friends 7800GT and is also shorter than my motherboard at 9.45"
  3. scq
    scq What's a Dremel?
    4 Mar 2005
    If the GTX is the same size as the X1900XTX which I have, the card is LONG. I think it's 9 inches or something. I briefly had a 7900GT from BFG (reference board - but blue colored PCB), and it was a little over 7,3/4" - close to 8 if you include the space for the PCIe power connector.
    I'm going to guess the 7800GT would be the same size as the 7900GT.
  4. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    The 7800GT is a big card, but I can't really be bothered to go inside my case to measure it.
    But it's BIG.
  5. [1N0V471V]
    27 Feb 2006
    It's not. The 7900GT is shorter by a noticeable amount...
  6. Glider
    Glider /dev/null
    2 Aug 2005
    For gods sake, someone open the case and measure it... No use in disputing the relative length, just measure it...
  7. lcdguy
    lcdguy Minimodder
    25 May 2004
    but why would we do that :).
    i have an x1900xt and it's almost as long as my mobo is deep :D
  8. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    :rolleyes:
    Anyways, my X1800 XT is 9 inches, my friend owns a 7800 GT which a bout 1 inch less than my X1800 xt so about 8 inches and looking at this pic the 7900 GT comes up to the vregs on the X1800 XL which measures in at 7.6 inches.
    End of
  9. jeff00z28
    30 Jul 2006
    eh i guess ill just buy the gtx and have to cut the case to make it fit. I want a really high end card since my x800 pro wasnt good enough imo.
