Graphics Cards to run a Dell u2711
Discussion in 'Hardware' started by LukeDaly, 19 Nov 2011.
  1. LukeDaly
    LukeDaly Pokemon Master
    9 Jun 2011
    Hello,
    ive been reading reviews all week on this Dell u2711 monitor and im still unsure if i will be able to max all games with 2x 6970's at 2560 x 1440 ?
    any help is appreciated
    Luke
  2. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    imo you could max pretty much anything with those
    id estimate that would get about 45-50fps on bf3 at ultra? not sure
  3. Krzysztof
    Krzysztof What's a Dremel?
    19 Nov 2011
    With 2 6970 in CR there should not be any problem at 2560X1440, however i going to ask you why did you ask for 2560 x 1440?, the max res for 27" monitors is 2560X1600 on DVI or HDMI. And dont forget you need also a very good CPU to take full advantage of CR esspecialy in hi-end cards like 6970.
  4. LukeDaly
    9 Jun 2011
    id be hoping for at least 60 in all games tbh :/
  5. Cyndre
    Cyndre What's a Dremel?
    12 Apr 2010
    I'm able to play perfectly with ultra settings with silky gameplay on a u2711 with 2 x 1.5GB EVGA GTX580 Hydrocopper 2's.
  6. LukeDaly
    9 Jun 2011
    sweet man, how much power does sli 580's take?
  7. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Play Battlefield 3 on high settings with two GTX 460 in SLI, when superoverclocked it's really smooth at maximum U2711 resolution!
  8. j4mi3
    28 Jun 2011
    bf3 is intense. and you do realise this is a super resolution. you would need dual 590's to get above 60 in bf3, ON ULTRA.
    and in a few other newer games today. like metro.
  9. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    A friend of mine plays on that exact screen, and uses 480 SLI. He's very close to 60FPS, ultra setting, 2x MSAA. Also important to mention: he has it coupled it with an 875K @ 4GHz.
  10. lm_wfc
    lm_wfc Minimodder
    18 Feb 2011
    Just turn down to high if tiy want 60hz plus fps. It'll cost you over a hundred extra for ot
  11. lm_wfc
    lm_wfc Minimodder
    18 Feb 2011
    If ra released bf3 capped at high, and and ultra version for 150 would you pay the extra?
  12. Krony
    Krony What's a Dremel?
    30 Jul 2011
    sli 3Gb 580's will do 60fps in BF3, quad sli 590's are a waste really.
  13. LukeDaly
    9 Jun 2011
    was thinking that man, how much power do 580's take up?
  14. Krony
    30 Jul 2011
    Most i have pulled from the wall is just under 900w which is about 810w @ 90% effeciency but that was benchmarking with some pretty hefty overclocks.
  15. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Tri-SLi 3GB GTX580s. It's the only way to be sure you get constant 60fps really. :D:lol: In all seriousness, why do you need at least 60fps?
  16. Krony
    30 Jul 2011
    Considering an LGA2011 upgrade myself after Christmas and adding a 3rd 580 and a U3011 :p
  17. j4mi3
    28 Jun 2011
    that. 45-50fps is personally the highest id really care about. i wouldnt go lower than 30 though
  18. LukeDaly
    9 Jun 2011
    i want to build a decent system that will last me a good bit, and 40 - 50 fps on bf3 on ultra?
    what will games be like in a year if thats all i can run bf3 on ? :/
  19. lm_wfc
    lm_wfc Minimodder
    18 Feb 2011
    Well given that bf3 is way ahead of everything else out, you'll still be alright in the year.
    Why do you want it to last you years
    when its slow, then update it, no point paying today's prices for tomorrow's needs.
    3lusive likes this.
  20. j4mi3
    28 Jun 2011
    bro recently upgraded my ram, mobo, and cpu (see sig). theres nothing that those components cant handle, but in 3 or 4 years, il bet my life that there will be something better
    and as above, bf3 is way ahead of other games right now
