Cooling Cascade 4 gig action
Discussion in 'Hardware' started by fatty, 25 Mar 2006.
  1. fatty
    fatty Minimodder
    12 Jul 2004
    you can find my build HERE
  2. FIBRE+
    FIBRE+ Minimodder
    27 Feb 2005
    Nice one :thumb:
  3. SpleenBeGod
    SpleenBeGod What's a Dremel?
    19 Mar 2006
    is that a pc with an ac in it, or a window unit with a pc in it?
    heh, nice
  4. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    That's just with -50? Why so limited - coldbug, or compressors?
  5. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    Nice! I want one :lol. A very nice clock too, you should get one of those 0601 3800 X2's under that.
  6. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    4ghz :jawdrop: :waah: :thumb: lol
  7. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Think it's 'cos the Cascade is only running CO2 at the moment..
    Awsome results mate :D Congrats :D
  8. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    regass with a 404a/502 mixture then you'll see -100
  9. Fozzy
    25 Jan 2005
    also -50 on the proc means about -78-82 off the proc. That's actually pretty good.
  10. fatty
    fatty Minimodder
    12 Jul 2004
    I want to regass the high side with R23 at the moment it is a blend of R507 and CO2, CO2 is not the best gas to use but its all I had also the unit will do -100 but it isn't usable at that as it is too light a charge
  11. Gray Mole
    Gray Mole What's a Dremel?
    30 Dec 2005
    Once again, congratulations Fatty :D Good to see you not only got that cascade running well but you also got that magic 4ghz :rock:
    402a/502/507/404a are all first stage gasses. Regassing to 402a from the R507 he's using won't really do a lot for him. Maybe a degree or 2 at best for the heat exchager itself.
    CO2/R23/170/1150/508 are all the 'cascade' or high pressure gasses. Generally for -100 load action you need either 1150 or 508 for that kind of temperature.
    Normally you'll see around a 40c difference from evap temp to cpu core temp on a cascade so that's about right.
    Once again, great work, you've only got another 100mhz or so to bring the WR to the UK :thumb:
    Cheers
    Gray
  12. fatty
    fatty Minimodder
    12 Jul 2004
    World record is 4101 for an AMD so just a shade over will do me just fine :) when I pull the big gun out again I will shoot for some higher scores and maybe a WR :eeek:
  13. chemo
    chemo True Jungle Brother
    20 Feb 2005
    good luck with the WR, and congrats onthe magic 4ghz
  14. sc4mpi
    sc4mpi OG watercooler
    16 Jan 2005
    wow.. nice one :), if you aint changed the fx since we last spoke on msn. mines the same stepping and week, so theres hope for mine yet :D
  15. fatty
    fatty Minimodder
    12 Jul 2004
    Well bring it over I can always test it for you :)
  16. sk8ter646
    sk8ter646 Minimodder
    4 Oct 2005
    only one slight problem that would be a bit big to take to a LAN
  17. gmarappledude
    gmarappledude What's a Dremel?
    13 Nov 2005
    Nice mods there. Um what games do you play on it. Fear, oblivion!
  18. Highland3r
    25 Jul 2003
    Minesweeper/Pong probably ;)
  19. Fozzy
    25 Jan 2005
    ROFL
  20. unrealhippie
    unrealhippie What's a Dremel?
    24 Jul 2004
    Now before someone shouts overkill, I felt the need to add - pong is the only game worthy of this setup :D
