Cases Case advice: Azza Solano vs HAF 922
Discussion in 'Hardware' started by Dragnoer, 19 Oct 2009.
  1. Dragnoer
    Dragnoer Is a nice person... really
    6 Oct 2009
    AZZA Solano 1000 ATX Full Tower
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811517004
    COOLER MASTER HAF 922 ATX Mid Tower
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
    which is a better case for the money, I have heard good things about the HAF 922, but I have never heard of AZZA much less the "Solano 1000" before. Please advise?
    are fan filters that important? HAF 922 has them AZZA does not.
    I realise the HAF 922 is a Mid case and the AZZA is a full, they both work for my mobo and GC's. is there any advantage to a full case besides size?
  2. Kyocera
    Kyocera The Garden of Evil
    9 Sep 2009
    HAF 922 is prettier.
    Otherwise filters are important, because you don't want a vacuum cleaner, 922 is big enough to accommodate any build, 922 has gone through reviews proving its value,..
    I'd take HAF 922.
    Bigger case means more space for your hands when putting together, or watercooling,...
    Smaller case like HAF means better air cooling since all fans are blowing across your hardware,..
  3. bagman
    bagman Minimodder
    18 Apr 2009
    +1 for the HAF 922
  4. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    That Azza looks like an Antec 900 rip off and although the 900 is good it doesn't compare to the HAF 922, the HAF 922 looks a lot better too
  5. Dragnoer
    6 Oct 2009
    thanks all I have decided on the HAF922, let the build begin
  6. docodine
    docodine killed a guy once
    10 Feb 2007
    I wouldn't write off the Azza, it looks like a much better deal. Comes with a lot of fans.
    I'm also a sucker for black painted interiors..
  7. bagman
    bagman Minimodder
    18 Apr 2009
    it comes from a genric manufacture and it is probably going to be terrible build quality, lots of plastic and no cable management it would like buying a thermal take case
  8. docodine
    10 Feb 2007
    Reviews on the Solano aren't that bad, so idk.
    Saving $20 over the HAF 922 is worth taking a bit of a risk IMO. I think the Azza looks better actually, the HAFs both look pretty weird.
