Case Mod - In Progress Case Corsair 730t FORD Mustang Shelby GT500 Theme - PIMx99
Discussion in 'Project Logs' started by Zerous12, 18 Jun 2017.
  1. Zerous12
    Zerous12 What's a Dremel?
    31 May 2017
    Prototype Rv01
    The main idea of the project is to insert the liquid refrigeration giving it a unique touch and car tunning type always reserving the essence of a Muscle Mustang Shelby car that I love.
    Since the budget managed by me is very limited to not having external support for the important parts of Hardware and Watercooling this project is going to take a slower course.
    Wait patiently :p
    XSPC RAdiator 280
    Barrow Waterblock Black and Filter
    Spec: Motherboard: Strix x99 -
    CPU: Intel Core i7 5820k
    Ram: PNY anarchy 32GB DDR4 2666 mhz
    Without further ado, let us move on to what matters. The modding
    Wait ... first remove the cat from the box ..
    Now if we continue..
    okay..
    Well ... I have to make a new methacrylate panel, because the original can not be soldered or modified
    Reason: because the case had a very ugly blow.
    Always protect yourself, even without equipment, you have to do it anyway
    Result
    I did not pass the Gravity Resistance Test. The supports were poorly implanted. :waah:
    Second Chance, we already learned the lesson :wallbash:
    Now Yeah!:rock:
    Let's work for the case but the cat again .. ATTACK!
    PSU cover!!
    REPAIR BRICKS
    ///It's so bright that it mows my eyes
    Finalized
    ///How sexy
    Let's go for more
    Dot_Kappa likes this.
  2. Zerous12
    31 May 2017
    Let's continue.
    Sandblasting.
    Thank you Hydrosa for Existing in Paraguay xD
    Reinforcement of corners. The Corsair 730t does not bring you even though you need it more than the Corsair 760t
    Support for reservoirs
    Paint partially or oxidize everything xD
    GPU Vertical bracket
  3. Zerous12
    31 May 2017
    Prototype panel RV01 tempered glass
    Installation of the support for the left panel of tempered glass
    Support for the Reinforced panel
    Same steps of briquetting
    The Tempered Glass arrived!
    Thanks Templex! :thumb:
    Here is the key
    Presentation
    Cut unnecessary parts
    I get the front panel at last! :rock:
    ///I do not late much and I already mount it to see how it is haha
  4. Zerous12
    31 May 2017
    Front cover
    The parts go to HYDROSA Paint Shop to put it luxury
    Let's continue with the left panel while we wait for the parts
    OBS: Has half perforations to generate space for adhesives
  5. Zerous12
    31 May 2017
    The parts arrived !!
  6. Zerous12
    31 May 2017
    We solve some unforeseen errors
    Yes now! To the paint shop!!
    Now a photo session. Sorry for my bad camera :(
    I was already missing something xD
    backlight Bracket GPU
  7. Zerous12
    31 May 2017
    Well already arrived the adhesive, the primer and the rubber painting
    We work by tempered glass to leave a special paint mark well known in the world of motorsport, remember those black stripes of the windshield? For that is !!
    Unfortunately it is very toxic so wear latex masks and gloves
    Check that there is no dirt
    Drying is carried out and a temperature of approx. 55 ° C is obtained for a rapid drying of 2 minutes with an ambient temperature of 22 ° C
    We paint the most delicate part first. Where are the numbers
    PBS: if you ask what it means, it's only my birth year 1991 but otherwise ordered haha
    Hand painted, this is subject to failure
    Also the panel with which it will adhere
    We introduce..
    We caught
    :D
  8. Zerous12
    31 May 2017
    Finally my order arrives for more parts of PerformancePcs
    While it remains so.
    As soon as I have Updates I upload it!
    Thanks for stopping by this place.:D
    Cheapskate likes this.
  9. Zerous12
    31 May 2017
    Hello people !!
    I am sorry for the delay with the updates, but these months have been difficult for me to overcome due to the lack of time.
    As you already know, the model is an art and you must take it with patience and freshness to add new ideas to the project.
    No more excuses, more news, more information possible in the registry in the shortest possible time!
    Fan Grill Shelby MOD
    Thanks to FAST PC Informática and CyT Intelligent for Support
  10. Zerous12
    31 May 2017
  11. Zerous12
    31 May 2017
    Hello people!
    I bring an injection of updates!
    I am very sorry for not being able to update them less frequently, 2018 was a bad year for me, so much that I could not get the GTX 1080Ti because of its high cost and that is why I delay the registration too long , but be assured that it is the only place where you will see this project finish!
    Without any more preambles!
    More parts of the WCC arrived
    Copper pipes T - 41
    A wash before starting.
    Don't worry, it has black paint with electrostatics and red polyester paint with three layers of varnish
    Beautiful packs of Phanteks HALO
    [​IMG] [​IMG]
    EK PE240 Radiator
    Fold, try, fail, keep bending until it looks good.
    First curves finished.
  12. Zerous12
    31 May 2017
    Copper pipes ready for a black paint.
    EVGA RTX 2080 !!
    Water block EVGA HYDROCOPPER 2080 got!
    Of course there could be more failed attempts.
    - Again!
    It warms until it becomes purple, after cooling it, we fold very carefully
    Background paint to fill in any type of scratches or damage
    and ready!
    While the paint dries, make corrections of wires in the alphacool pump that came with a problem in the pin outputs
    Rear LED lights for I / O and GPU
  13. Zerous12
    31 May 2017
    Once assembled everything ...
    It looks like this!
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Its alive!
    is 90% finished
    There is still work on the details on the side panels, PCI cover, Bay cover, and a detail on the PSU cover that you will see below.
    This is Version 2.0 of the first fan grill
    The main idea does not only change the design to be less obstructive and release it so they can have it
    https://grabcad.com/library/fan-grill-shelby-rv02-140-mm-1
    This is the list of all the parts of the Loop
    https://mega.nz/#!fhkChQzY!hlNOEnqWi-FePimjHV4wz8PQkbDeXzafok_z-9TVof4
    Thank you for visiting this registry.
    See you the new year with more updates!
    Dot_Kappa and Cheapskate like this.
  14. warboy
    warboy Insane modder
    24 Nov 2011
    I really like how you positioned the tank .. The painting is fantastic :)
    Zerous12 likes this.
  15. Zerous12
    31 May 2017
    Thanks for comment!
    And I found it a bit strange since I did not resort to putting it as people would normally do, the idea was born when I put a sketch of the prototype in a forum to feed me more ideas to the project so someone commented about: why not put it to 60 degrees of inclination since you will not use the bays?
    and there you have it haha
    I also doubted the way to purge the system of the bubbles, but it is solved by loading a reservoir first, and emptying the other making the effect of suction, it is a process that should take me only 10min, it takes me more than an hour, I plan to solve this problem including a vacuum valve in the return of the EK radiator to return the bubbles outside the system and not modify the entire loop path, but I think this is already out of the register, but any news will be published in the modding sector at the end.
    Happy new year to everyone ~!
  16. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Looking at the first pics I didn't think it would have turned out in that way.
    Amazing result !! :jawdrop:
