Case Fan choice...?
Discussion in 'Hardware' started by D-an-W, 17 Aug 2006.
  1. D-an-W
    D-an-W What's a Dremel?
    9 Nov 2002
    I am looking to replace three of these ANTEC Case Fans in my current setup. They are speed controlled by my PSU so run fairly quiet but at the speeds they run at I don't think they shift much air :duh:
    Could anyone advise me on what a good replacement would be, I will hopefully run at least one (If not all!) from the motherboard variable controller and perhaps the other if required from the PSU.
    I am not concerned about LED's in the new ones, just want them to be as efficient and quiet as possible...
    TIA...D-an-W
  2. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    80 mm fans 3x These are good fans and
    this will allow you to control the speed and sound levels of the fans. If you can go 120mm.
  3. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    The Akasa Amber 80mm fans are nice and quiet.
  4. Hazza
    Hazza What's a Dremel?
    25 Nov 2003
    sharkoon fans are s'posed to be very good
  5. D-an-W
    9 Nov 2002
    Thanks, will check them out now :D Whats classed as silent or won't be heard above HD noise?
  6. dragontail
    dragontail 5bet Bluffer
    9 Jun 2005
    Sharkoon fans are indeed quiet good. You need to read Custom PC's latest issue, they did a massive fan test.
    Depends on you're hard drive :p
  7. D-an-W
    9 Nov 2002
    In all good newsagents now...I assume?
  8. dragontail
    9 Jun 2005
    yes, indeed. Plus I asked about that at silentpcreview froums a while ago, and the guys over there made some interesting observations. I would link it, but SPCR is currently not loading in my browser so I'll linky as soon as its working for me again.
    EDIT: linky http://forums.silentpcreview.com/viewtopic.php?t=32919
  9. D-an-W
    9 Nov 2002
    Thanks, just added to my confusion....:D Gave me an even longer list of choices to compare now :duh:
  10. specofdust
    specofdust Banned
    26 Feb 2005
    Just to point out, CustomPC's latest fan test had quite a few flaws according to the guys over at SPCR forums, the basic jist I got from what most of the guys there were saying was, the testing CPC did is innaccurated and biased towards certain fans(not saying intentionally, just the way they tested favoured some designs and not others).
    Check out my thread here also, if you're intrested in quiet fans.
  11. D-an-W
    9 Nov 2002
    These seem to fit the bill quite well and would give me a bit of colour similar to the ANTEC Blue LED ones I have now :idea:
    Are these fans really that quiet at the full 12 volts as I am waiting on the arrival of my Seasonic M12-600 PSU from Germany to see what (If any) fan control it includes as the P5N32 SLi SE Deluxe MoBo only has one Fan Header that has a variable output. I have used two fans off one header in the past however, is this ok?
  12. cpemma
    cpemma Ecky thump
    27 Nov 2001
    There's no fan that moves a lot of air quietly. Low-noise fans run at low RPM, low RPM gives low air flow. The Antec fans claim 34cfm @ 30dBA; the Sharkoon linked 22.7cfm @ 17dBA so it's shifting far less air.
    Some fans are better than others at a given RPM by bearing design and build quality, but if you want very low noise you have to put up with lower flow and higher temperatures.
    Best solution is bigger fans, 120mm rule.
  13. D-an-W
    9 Nov 2002
    The Antec ones are by no means running at full speed now, I guess I could stick the Fluke on there and see what voltage they are getting...
