Alright after getting the news that the LCD i pulled from a portable was destroyed due to my eagerness. But now i shall be asking for your ideas and input on upgrades and some aesthetics. k first one to discuss is system fans: im looking to either buy all new system fans so that they all match or buy corresponding case fans. should i go with fast fans and sacrifice noise dampening, or should i go with slower fans and hopefully keep as much noise reduction as i can I plan on getting 4 80mm fans to help pull air out of my case right after the air has come in to cool the radiator, instead of pushing the "hot" air back into my case adding heat inside where no one wants it. the fans will be placed two side-by-side on both sides of the case. whilest ill have 3 120mm fans, one in on the back, on in front, and the last on the side. i current have 2 roswell 120mm fans on the side and in the front, and 1 120mm fan that came with the case on the back. my 2 roswell fans glow/light up bluish green. im going for a blue lighted case, but i dont wanna go crazy with the lights and make it too much. any one have any input, ill post a pic of my 120mm fans on here when i get back to my desktop and ill be able to show it to you guys while they are lit up. also wondering if it would be a good idea to use fan filters to help keep the inside clean? so if youve got a great fan that your using right now id like to know what it is, or if you know what has a great review or "rank" id appreciate it. k thnx
