Cooling case fans
Discussion in 'Hardware' started by surtur, 19 Feb 2008.
  1. surtur
    surtur What's a Dremel?
    11 Feb 2008
    There are a lot of companies making case fans out there, are some superior to others? I can only assume. I don't care about flashy led's just a quality fan.
  2. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    That's a loaded question, because there are a fair number of traits you can judge a fan on. There are different 'best' choices for low noise, high airflow, controllability, a good ratio of noise to airflow, good pressure capability, and so on.
    If you're looking for a good all-round fan, get an Antec Tricool. The built-in 3-speed controller lets you select the appropriate amount of airflow for your needs.
    If you're looking for a fan with an exceptional airflow-to-noise ratio, look at the Noctua NF-S12 series. These fans have very poor pressure capabilities, though, so while they make excellent case fans they do poorly mounted on heatsinks.
    If you want overall low noise with a nice balance of pressure and airflow, either get Scythe S-Flex fans, which are available in three speeds, or get a Nexus Real Silent (my personal favorite).
    If you need raw power and nothing else, wait for someone else to reply.
  3. sheninat0r
    sheninat0r What's a Dremel?
    28 May 2007
    Id take a Yate Loon over a Nexus, as YL is the manufacturer for Nexus fans and Yate Loons sell for $3 and Nexuses for $10.
    Deltas, Tornadoes, Sunons, and Sanyo Denkis are all high-performance fan makers - high performance as in multiple hundreds of CFM at 50 dBA and up. Nothing I'd use in any of my computers, but... they're there
    Noctua's S12 is, like crazybob said, a very good case fan but a poor heatsink/radiator fan. The NF-P12 was designed to solve these issues, and works much better on things that need back pressure.
    Scythe S-Flex fans are good, but outdated - the new Slipstream line has more airflow per dBA and higher pressure, and comes in speeds from 500RPM to 1900RPM iirc.
  4. crazybob
    21 Oct 2004
    I understand there's a small difference in the design of the shroud, which makes the Yate Loons a bit louder. For most people, I suppose it'd be a worthwhile tradeoff, but if your main goal is low noise there's some benefit in the more expensive Nexus.
  5. sheninat0r
    28 May 2007
    IIRC, the difference is closed corners versus open corners, which affects the length of the screw needed to mount the fan. Yate Loon D12SL-12 fans are closed corner, and Nexus Real Silent 120mm [also model number D12SL-12] are open corner. Yate Loon now makes them in open corner configurations also, but the only thing that would affect quietness is the fact that you can't use most vibration-dampening mounts [designed for open corner fans] on closed corner Yate Loons. However, with the new open corner models that's not an issue.
    Oh yeah, Yate Loon models are either all orange or all black, and Nexus models are black shroud/white blades.
  6. SaII
    SaII What's a Dremel?
    7 Jun 2006
    if you can find a place to buy sanyo denki san ace 1011's, get those, they are the best fans in the market
    second best would be sharkoon golf ball 2000's
  7. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    Not true, there are the rubber/silicone vibration-isolating mounts for closed corner fans. They come in black as well as some uv reactive colors. See http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=325&products_id=20642 . Of course it does depend on your location. But look around and you should be able to locate some for your build.
  8. cosmic
    cosmic What's a Dremel?
    6 Jul 2007
    Read some good things about those Scythe Slipstream fans, so will probably be the next model I try. Scan do not stock them and not seen any in my other shopping outlets, so waiting at the moment.
  9. sheninat0r
    28 May 2007
    Hence, "most vibration-dampening mounts"... I know they exist, but they are less commonly found than open-fan mounts.
  10. wyx087
    15 Aug 2007
    so you guys are saying yate loon fans are not the best for heatsinks? (namely push+pull config in Thermalright Ultra 120 Extreme)
  11. sheninat0r
    28 May 2007
    Yate Loons are fine for heatsinks... the Noctua NF-S12 series is bad for heatsinks, since it has very low pressure.
    Yate Loons on an Ultra-120 eXtreme might be a problem, since the wire clips might not be designed for closed-corner fans. Other than that, they should be fine.. and the clips can be easily fixed by bending them or replacing them with tape or zipties.
  12. wyx087
    15 Aug 2007
    it's Noiseblocker bought from this forum, made by Yate loon. so mounting fine. thanks
  13. talladega
    talladega I'm Squidward
    18 Aug 2007
    what fans do you guys recommend for on radiators?
    I noticed that the life expectancy for Yate Loons are very low compared to others. Does this make a big difference or is the Yate Loons just fine?
  14. SaII
    7 Jun 2006
    yate loon high speed from petra's tech shop are great.
    get it from there because they are the only shop that talks directly to the yate loon company, thus good quality.
  15. tomshawn
    tomshawn What's a Dremel?
    7 Mar 2008
    Noctua P12. Period.
  16. sheninat0r
    28 May 2007
  17. rodeo45
    rodeo45 Who's your daddy ???
    4 Mar 2008
    I tested Noctuas with loons - Noctuas are better. Flex are also good
  18. Zargon
    Zargon Master of the Universe
    16 Feb 2008
  19. sheninat0r
    28 May 2007
    After some reading, the 120x38 Denki San Ace 1011 definitely seems to be one of the best high-ish RPM fans [2600RPM], and it undervolts well while maintaining a similar level of performance - IMO one of the better and more flexible fans on the market, except for the thickness. There's only two places to get them in the US though, and more in Europe. Here in the US, FrozenCPU stocks them for $30 :wallbash:
  20. rodeo45
    4 Mar 2008
    Denki are the cheapest compare to others and still pretty good, as long as you gonna keep them on decent speed
