Modding case feet
Discussion in 'Modding' started by jokkos, 23 Dec 2005.
  1. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    does anyone know where I can buy some casefeet like the ones of the Coolermaster Stacker (link )? Preferably in Europe. Thanks!
  2. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    hmmm, not that i can think off, maybe have a look in your local hardware shop? they may have something similar, or if they dont, get some and stick some felt pads to the bottom. does your case not have feet?
  3. Blackcrown
    Blackcrown What's a Dremel?
    1 Oct 2005
    Never seen casefeet for CM stackers. Maybe making your own like how you want it to be. :p
  4. H311R4153R
    H311R4153R What's a Dremel?
    28 Mar 2005
    You could probably find some at a store for speaker and amplifier parts. Or try and find an old amp or cd player, they often have these feet underneath them.
  5. Nexxo
    23 Oct 2001
    You'd have to find an old (broken) stereo on a dump somewhere and cannibalise them. For some strange reason they are one of those common objects that are just not for sale loose anywhwere. Trust me, I've looked. There are no acceptable substitutes either so you'd have to go the scavenging route.
  6. THEkorean
    THEkorean 42
    10 Jun 2005
    steal them off an older cooler master case? i have a wave master and they have the exact same feet
  7. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    I have the CM stacker casefeet that I no longer need (I'm using wheels instead), you can have them for postage.
  8. Nexxo
    23 Oct 2001
    If jokkos doesn't take them, I'll have them. :D
  9. mattthegamer463
    26 Nov 2004
    yeah, find an old vcr (or a new one) and steal the feet of them. thatd be your best and cheapest bet.
  10. jokkos
    10 May 2005
    hmm thanks for all the replies.
    I actually do have a good idea for casefeet for my case, but I always read reviews for htpc cases and some of them have those hifi-feet. And I like the looks of those, would be easier as the idea I have in mind as well. Anyway I already came to the same conclusion: unavailable in stores, and need to find an old unit somewhere that I can mutilate ;-)
    okay, I'm probably going to make my own casefeet, since I would like to use 6 of them instead of 4 that would be on most units or are on the Stacker.
    So MrWillyWonka, thanks a lot for the kind offer but I'm going to pass since I need 6 of them, and Nexxo, I guess this is your lucky day :D
