Cases Case feet
Discussion in 'Hardware' started by dinoscothern, 19 Sep 2013.
  1. dinoscothern
    dinoscothern Minimodder
    16 Aug 2010
    I've got a Fractal Design Arc Mini, my floor is a thick carpet and the gap underneath is a bit narrow.
    I'm worried about air flow, and was wondering if its sensible to fit taller feet?
    I could put a bit of sheeting/hardboard underneath but that feels a bit naff.
    I'm not looking for classy expensive feet, but ones about 2cm tall and hopefully cheap.
    Any suggestions please?
  2. wufer
    wufer What's a Dremel?
    18 Nov 2011
  3. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    If its a carpet floor I'd be tempted to use something like a half ball shaped foot that will slide along the carpet easily, rather then the fluffy type linked above. Not sure how they will last long term. I'd personally look for something which screws to the case from the case insides into the foot.
    More this style of fitting: http://www.kustompcs.co.uk/acatalog/Case_Feet.html
  4. Nexxo
    23 Oct 2001
    Alternatively, look at speaker feet or "cabinet spikes".
  5. dinoscothern
    16 Aug 2010
    Thanks, I've seen a 'Rubber Cabinet Foot 1" Dia. x 1" H' that could be suitable.
    Not flashy, but about right.
  6. dinoscothern
    16 Aug 2010
    Ever the cheapskate I've settled on using a bunch of demijohn rubber bungs from the local homebrew shop at 75p ea!
  7. Ola.l
    Ola.l What's a Dremel?
    5 Aug 2009
