Cases Case feet
Discussion in 'Hardware' started by stormbringer500, 15 May 2015.
  1. stormbringer500
    stormbringer500 What's a Dremel?
    6 Jan 2010
    Hi there this may be a stupid question but I will give it a shot. Does anyone know if you can get feet for the HAF X case I am currently using casters but something a bit more sturdy would be better. Thanks.
  2. bulldogjeff
    2 Mar 2010
    Is THIS the sort of thing you're after?
  3. stormbringer500
    6 Jan 2010
    Yeah like that, Thanks never heard of that site though.
  4. Nexxo
    23 Oct 2001
    They're solid. Been on the modding scene since the late 90's, have a very good reputation.
  5. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    I replace case feet with these kind
    high chunky feet. They are labeled as being for amplifiers, but they bolt through the same way as what you need for many PC cases. They are nice and high so if you have bottom mounted PSU or bottom intake fan they give plenty of clearance. Work real good for eliminating vibrations too. The biggest thing is they are real cheap, only about $5 for a set of 4.
