Cases Case for 2 x 360mm rads without modding?
Discussion in 'Hardware' started by dead beat, 12 Oct 2011.
  1. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    As the title suggests really. I've looked at the Mountain mods cases and the Dangerden offerings, however I'm a bit put off by the cable management of these cases. One of the things I like so much about the 800D is the cable management.
    Any suggestions would be greatly appreciated.
    Cheers
  2. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    Internally, and without modding?
    Can't think much of anything, maybe XSPC H2, or something from Case Labs/Little Devil? Those are pretty expensive though.
    //edit: Xigmatek Elysium?
  3. dead beat
    15 Feb 2009
    I'm not a fan of the Xigmatek particularly. The only other option I could find (which you suggested) was the XSPC H2. However, that's ugly as sin.
    I'm thinking that it's just looking like I'll have to mod the 800D.
    SlowMotionSuicide likes this.
  4. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    I think you'd be better off modding the case. The caselabs cases have plenty of room but it would be costly like SlowMotionSuicide said.
  5. Ant1981
    Ant1981 Minimodder
    4 Dec 2008
    I like mods for external rads, best way to get rid of the heat is to not dissipate it inside the case.
  6. dead beat
    15 Feb 2009
    Yeh but in watercooled systems, most of the heat is in the waterloop. The ambient temp inside my case is quite cool.
    I've just ordered all the equipment for a second loop, so watch this space for pics.
  7. Ant1981
    Ant1981 Minimodder
    4 Dec 2008
    The heat is in the waterloop, then goes into the raditor to be lost, then cool water returns to the loop, that's the point I'm trying to make. Lose the heat outside.
  8. SlowMotionSuicide
    16 May 2009
    +rep for having an excellent taste in computer cases, good sir.
    Do you have the rads already? Because if not, you're better of modding the top for 480mm, which it will take easily, and placing a 240mm to lower compartment. Putting 360mm rad in the bottom will be challenging, at minimum.
  9. dead beat
    15 Feb 2009
    Ha......cheers.
  10. sheninat0r
    sheninat0r What's a Dremel?
    28 May 2007
    Mountain-Mods makes cases that can do this, but I don't know how available they are in the UK.
    Edit: Whoops, I didn't see that you already decided against MM.
