Scratch Build – In Progress case from alu and perspex, FINISHED
Discussion in 'Project Logs' started by rambo, 10 Apr 2008.
  1. rambo
    rambo What's a Dremel?
    14 Mar 2007
    hi thanks for the reply's and no it is not heavy it is pritty light :D:hehe:.
  2. Slatter
    Slatter Mesh Addict
    16 Feb 2007
    Nice Work... Looking forward to this seeing build develop...
  3. JBLPL
    JBLPL What's a Dremel?
    5 Mar 2008
    Very nice :D. Dont mess it up and five stars guarantee ;-)
    *subcribed*
  4. The boy 4rm oz
    10 Apr 2008
    Very nice start. I love the way the frame goes together. That rear panel looks great.
  5. rambo
    14 Mar 2007
    thanks for the replys, I am not planing to mess it up :lol:. I am designing the dvd/ hdd bracket so I can make it wile the alu bars are gone, I ame thinking of making it from plexi glas, also I am thinking of making the reservoir (for my water cooling) my self :dremel:. So there is going to be allot more to come I hope :D.
    see ya, julian
  6. rambo
    14 Mar 2007
    hello, here is a small update of what I ame going to make, it are simpel drawings of the sidewall and the top of the hdd/dvd bracket, the 4 M5 holes in the middel of the top plate are for mounting it to my case, the 4 small lines in the side are suposed to be m3 holes so I can mount the sidewalls to the top :dremel:. In the sidewall you can see 8 small groves they are for mounting the hdd/ dvd to the bracket :hip:, on top of the sidewall you can see 2 small holes those are for mounting it to the top plate. All the plates are from perspex:
    side plates 5mm
    top plate 8mm
    4x M3x10 countersunk black steel screws
    4x M5x10 countersunk black steel screws
    2x hdd coolers so it fits in the same side bracket as the dvd and it ceeps them cool :brrr:.
    top:
    sidewall:
    see ya soon with pictures of the bracket, julian
  7. The boy 4rm oz
    10 Apr 2008
    It all starts as a sketch. Good to see you working on it. The finished product should look great.
  8. Guest-23315
    Guest-23315 Guest
    Very nice metalwork indeed :thumb:
  9. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    I like it a lot. Good engineering work!
  10. rambo
    14 Mar 2007
    thanks for the replys/compliments I am doing my best for it :D:lol:. Firts of all I am still waiting for the alu frame to come back in black from the anodiser so I dont have any thing of that, what I do have are some pictures of the hdd/ dvd bracket I made on my work.
    I milled the hdd/dvd bracket today it is a easy and simple disigne but he it looks cool. Here are some foto's of the perspex plates and the finale product, I milled it on the same kunzman as used before.
    So I used 5mm perspex for the side pannels and 8mm for the top pannel, I use 4 M3x +-12mm black steel countersunk hexagon screws and 4 M5 screws to mount it to the case.
    the 3 plates I used:
    tapping the M3 in the top plate:
    the side pannels 1 milled and 1 not milled:
    all the pannels next to each other:
    some different views of the hdd/dvd:
    and here it is with 1 old dvd player mounted in it:
    I hope you like it as mutch as I do,
    see you next time hope fully with the the black frame back from the anodiser, julian
  11. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    I've sent you a PM a while ago, did you see that one? The bays look pro! :)
  12. Macros_the_Black
    Macros_the_Black Yup.. I'm a f-ing reptile
    7 Jul 2007
    Very clean, very nice!
  13. The boy 4rm oz
    10 Apr 2008
    That is looking sweet. Love the drive bays.
  14. rambo
    14 Mar 2007
    hello, yes I found the PM yesterday :hip: I will put it on there this week. thanks for the replys and yeh I think it looks pretty nice also, but that is the thing with plexiglass if it is shiny and see trough it is nice (but that is my opinion).
    see you later, julian
  15. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    I like this Drive tray good job :thumb:
  16. rambo
    14 Mar 2007
    hello, a quick update:
    The alu frame is back in black :D. I only mounted the frame togheter because otherwise I risk to damage the perspex plates.
    all the components next to each other:
    the frame mounted 1:
    the frame mounted 2:
    the frame mounted 3:
    see you next time, julian
  17. JBLPL
    5 Mar 2008
    OOOOOK, black frame is awesome :D
  18. MrWizard
    MrWizard What's a Dremel?
    5 Feb 2008
    No joke. Thing thing looks pro! :thumb::rock:
  19. The boy 4rm oz
    10 Apr 2008
    It does look pro. Just one question. Why not gloss black? For this mod I think it would go much better.
  20. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    for a pro look you dont go GLOSS, you go SATIN. nuff said!
