Scratch Build – In Progress case from alu and perspex, FINISHED
Discussion in 'Project Logs' started by rambo, 10 Apr 2008.
  1. rambo
    rambo What's a Dremel?
    14 Mar 2007
    hello, thanks for the replys, and when you anodise something it comes out as a verry dry product (verry good cleaned/ no grease or something on it) so it looks satin but if you just rub some oil on it, it gets a little bit more gloss. I ame going to rub some oil on it because I think I like it better when it is a little bit gloss, update of that soon.
    ,julian
  2. The boy 4rm oz
    10 Apr 2008
    Well Burnout, no need to be snappy.
    I was just suggesting, I think gloss would go better with the plexi rather than satin. Satin would also look good, as Burnout so forcefully suggested.
  3. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    lol, just joking! but satin is the winner! lol!
  4. The boy 4rm oz
    10 Apr 2008
    Don't worry mate, I knew you were joking. I just wanted to see the reaction lol.
  5. MrWizard
    MrWizard What's a Dremel?
    5 Feb 2008
    Satin!
    Gloss!
    Satin!
    Gloss! :p
  6. The boy 4rm oz
    10 Apr 2008
  7. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    Wow, it looks amazing so far!
  8. rambo
    14 Mar 2007
    hey it is still satin and stays that way :thumb:. Today I picked up an old motherboard to place the mounting holes in the case and made some bushes from perspex to hold the board in the right place I did it with an old card placed in the old motherboard so that it has the right hight, I gluwed the bushesd to the perspex plate with a perspex gluw. I mounted the case togheter with the perspex plates this time I couldend wait any longer :naughty: see picture every thing fits just perfect.
    the case form a 3D view with a dvd player:
    side view:
    front view:
    back view:
    the case with the old motherboard in place 3d view:
    side view:
    back view you can see the bushes:
    hope you like it as mutch as I do, see ya next time, julian
  9. The boy 4rm oz
    10 Apr 2008
    All I can say is noice mate. Looks great, classy in its simplicity.
  10. Burnout21
    9 Sep 2005
    wire management has got to be perfect, messy wires in an acrylic case is a crying shame.
    would 10mm black Tygon tubing and nice raditors go nice in there, i think the answer is HELL YEAH! can i get a HELL YEAH PEOPLE?
  11. skullen
    skullen Minimodder
    31 Oct 2007
    Very nice, i do like a big case :thumb:
  12. rambo
    14 Mar 2007
    hey about the hardware that is going in to it I have a thermaltake toughpower cabel manegment power suply so I dont have a bulk of useles cabels. Also I have orderd Masterkleer 7/16" ID 5/8" tubing, black Feser one water, 5x Xilence 120mm red led Case Fans. For the radiator I am going to use my own ThermoChill PA120.2. thats it for now. The rest is mooistly from my pc I ame using now with some new adjustments.
    Julian
  13. MrWizard
    5 Feb 2008
    If you go about the wiring the same way you have with the rest of the case to this point, I'm not worried about it being sloppy in the least. :thumb:
  14. rambo
    14 Mar 2007
    hey again, I can't do moost of the things because I ame still waiting for some new things that I am going to use in this built like new watercooling stuf.
    What I did for this time is made some new case feet for the case, I used black delrin it is a very nice nonferro material. They are 40mm in diamater and 15mm high with a 4mm radius on the bottom (see picture). I am using a M5 countersunk sockethead screw to mount it to the case.
    here you can see the result:
    just the feet you can see the radius that I described:
    with the screws in it:
    al mounted under the case:
    under side:
    top side:
    hopefully there is more finished with the next update like: dvd player things, watercooling.
    se ya next time, julian
  15. The boy 4rm oz
    10 Apr 2008
    Those feet go perfectly. Nicely done.
  16. jhanlon303
    7 Sep 2006
    Seriously well done case. Looking good.
    But you seem to have a bicycle infestation - each picture has more bikes!:D
    John
  17. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    Was that Type II anodizing or hard-anodize?
  18. rambo
    14 Mar 2007
    hi, the bikes are not mine i work at a univerisity so the bikes are from the students. and I think it is Type II anodizing.
    ,julian
  19. rambo
    14 Mar 2007
    Hey there, I am making my own reservoir for my water cooling system it is 100mm round on the outside and 63mm high. The topcap is glued in the reservoir. The res is going to be placed on the middle plate of my case, see picture. I am going to make a round grove for the reservoir so it can be placed and glued on a certain position. Also I am going to make the tube connection holes on the bottom of the plate so that my tubes are going down. The little barb on the top of the cap is for the filport that I am going to mount to the top of the case.
    A quick sketch of the reservoir parts:
    The raw material: 1 peace of 100mm pipe 65mm long and 1 6mm plate 100x100mm(going to be 95 round)
    Here you can see the plate spinning around and I am making it round:
    the plate is forced between the spindle and the drill holder with a turning centre in it.
    Yeh the plate is now round 95mm:
    Making the cylinder on the correct length and stuff:
    This is the reservoir not mounted just turned:
    It fits just perfect:
    Tapping the 1/4" hole for the barb that is going to be on the top:
    This is the reservoir in total, only not yet mounted to the plate were it is going to be glued:
    And there is it going to be standing: (this is a older foto without the barb on the top)
    These were al the things I did to the reservoir, waiting for some parts to come in so that I can make the finale position etc.
    see ya next time, Julian :rock:
  20. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    nice work on the reservoir and clean case i love :clap:
