Modding Case Gallery - Pimp your mod! *Read rules before posting*
Discussion in 'Modding' started by cpemma, 30 Dec 2005.
  1. lowfat
    lowfat Minimodder
    4 Jul 2013
  2. -MisterX-
    -MisterX- Minimodder
    22 Apr 2014
    My current rig "PipeDream"
    I plan on posting the project log in the forum:)
  3. blueonblack
    blueonblack What's a Dremel?
    21 Jan 2009
    Project Open Air V2
    This was a scratchbuild made for CoolerMaster for CES 2014.
    Full Build Log
  4. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    I did this build in 2006. The door had to be replaced. It's hinge had cracked, which is very common problem with the Chieftec cases. We were lucky to find pristine donor case. The owner is retired employee from Harley Davidson. He doesn't game, but wanted to revamp his 8 yr old hardware without breaking the bank. We found him a good deal on decent hardware that will serve his needs for long time.
    Updated the LED lighting to true Orange color with these new PC light strips, http://mnpctech.com/pc-led-lights/
    Gave updated hardware Diamond plate accents
    http://mnpctech.com/case-mods-gamin...amond-plate-sheet/diamond-plate-sheet-en.html
    System specs from 2006
    Enermax 450W EG465P-Ve PSU
    DFI 925X-T2 P4 Mobo
    P4 3.2 GHz 800MHz FSB
    Thermalright XP-120 & LGA775 bracket
    SONY CD & DVDRW (airbrushed)
    2GB Corsair DDR2 (4, 512K sticks)
    2, 160 GB Seagate Barracuda HDs (raid)
    VGA - ATI|RDN 9600XT 256M 100575L-BK
    Current system specs:
    Corsair 750W
    ASUS Rampage III Mobo
    Intel 975 Extreme
    Corsair H100 CPU Cooler
    LG Black 16x Blu-Ray BDXL Internal rewriter with 3D Playback
    16GB GSKILL DDR3
    2x 240 GB Samsung 840 SSD
    MSI 550Ti
  5. Father Fuzzy
    Father Fuzzy What's a Dremel?
    14 Apr 2014
    Project Apparition
    Conjoined Antec p180 mini's
  6. LiljHoN_05
    LiljHoN_05 What's a Dremel?
    10 Jun 2011
  7. mnpctech
    21 Apr 2003
    This is my HR GIGER Tribute PC. It actually started this build a few years ago, but got shelved so I could take on customer commitments, so it has a mixture of old and new hardware, what prompted me to finally get it done, was HR GIGER's Passing on May 12, 2014, and the recent mod zoo "dust-off" event. If you've never of HR GIGER, he was most well known for his Visual Effects and design work on the first Alien movie, and of course the iconic Xenomorph ALIEN, long before working on that movie, he had established career as a painter, and had a very distinctive style that blended human bodies and machines that he described as "Biomechanical" ...which inspired the look of this PC..... the hardware as I said, is combination of old and new... the chassis is a Cooler Master 912 turned 90 degrees, and it's been 3 years since the asus sabertooth TUF shield was airbrushed with the Giger theme, the system has two seperate liquid loops, the stainless tube reservoir is for the GPU loop, and has Hardware Labs Black Ice 360 GTX, cooled with Panaflo L1As, these are 38mm thick, 68.9 CFM. Max. noise: 30.0 dB-A, the grill is from Mnpctech.com, with D5 pump and Alphacool top, the CPU is 3570, 3.4 GHz, with Swiftech's new Apogee XL waterblock, this a great waterblock for $69, and it comes with interchangable illuminated faceplate, my good friend EEL Ambiense designed a new replacement faceplate with a Giger-esque design, which I had laser cut, the cpu loop is PETG hardline tubing with EK 190 & DDC res / pump combo. Both loops are running distilled water. The system utilizes 32GB of their ADATA's new XPG V2 DDR3, and their Premirer Pro SP920 256GB SSD... I'll be using this PC in the shop for video editing primarily, so these two AMD Radeon 270Xs in Crossfire will save me from waiting for video to render all day... they're cooled with copper GPU blocks by Syscooling, just because I couldn't help myself...lol, and the power supply is a Corsair 750.
  8. colinmcr
    colinmcr What's a Dremel?
    1 Jul 2014
  9. irek83
    irek83 What's a Dremel?
    30 Aug 2014
    Project Black Pyxis
    Project Black Pyxis
    CASE: NCASE M1 Black Ser.No.0370
    MOBO: P8Z77-I DELUXE
    CPU: Intel Core i5-3570K
    COOLER: Swiftech H220
    MEMORY: Kingston HyperX Genesis 8GB DDR3 1600 2x4GB
    GPU: NVIDIA GTX 770 Reference GK104
    SSD: 2x Samsung 840 PRO 265GB RAID 0
    PSU: Silverstone Strider SFX Gold 450W
    CABLES: Silverstone SST-PP05-E, Silverstone CP11
    FILTERS: DEMCiflex
    WATER BLOCK: Aqua Computer Kryographics for GTX 770 Acrylic Edition
    edit @
    I put between the radiator and the side panel LED tape
  10. ec928
    ec928 What's a Dremel?
    9 Oct 2011
    Project Home Office
    Not quite a traditional case mod but more of an overall home office "room mod" that happens to include a case. I wanted a space efficient, quiet and powerful system for home office use that would also let me watch movies with 5.1 surround sound, and play graphic intensive games.
    That meant a mini-ITX build and A/V shelves that would hold the the PC, the receiver and all the cables without sacrificing any space. Watercooling was the only option for a quiet but powerful system. The XSPC AX480 quad rad with its eLoop B12-1's running at 650rpm and an EK-D5 Vario X-RES 140 pump set to a silent setting of 2 is more than able to cool my nVidia GPU and Haswell CPU (the coolant is Mayhem Pastel Sunset Yellow).
    Case cooling is via a 140mm fan @ 475rpm as the Seasonic PSU is passive. There are 8TB of HDD storage but the main O/S drive is a silent SSD. The 2560x1440 IPS monitor is movable via an Ergotron LX LCD arm giving me full use of the desk when needed, and the 5.1 speakers are held by unobtrusive speaker stands.
    In short, the system is powerful, takes up almost no space, and is very quiet.
    image link1 image link2 image link3 image link4
  11. jbfem
    jbfem What's a Dremel?
    22 Jan 2013
    copperHead 2.0 80% finish
  12. neilhart
    neilhart What's a Dremel?
    2 Feb 2011
  13. neilhart
    2 Feb 2011
  14. ElectRocnic
    ElectRocnic What's a Dremel?
    16 Nov 2014
    Here's really high quality stuff, I hope I can compete with my stuff...
    Sorry that I have NO pic, if you want to see it finished, please go to the last two minutes of the video...
    I only got that video, so if it's not ok due to the rules of this post, delete my post. sorry...
    https://www.youtube.com/watch?v=SS0ufm6pRBk
    Thanks for watching!!
  15. GeorgeK
    18 Sep 2010
    I guess we'll let a video pass :) I did delete your duplicate post though - once is fine :thumb:
  16. punkpablo
    punkpablo What's a Dremel?
    4 Dec 2014
  17. stressedmana
    stressedmana What's a Dremel?
    4 Feb 2015
  18. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Hi all!
    My Coffee table.
    MB Project 2.0
    Mercedes-Benz w126/500 original engine block is the basic of my work.
    Coffe table,wine and cigar holder and full featured computer all in one.
    Cpu and Gpu chilled with liquid Cooler Master Eisberg convert without radiator.
    The liquid circulating in the engine blocks water surface (3.5l) This large area provides sufficient refrigeration.
    Cpu 22-30c
    Gpu 32-40c
    The full weight of the machine 70 kg
    Glass cloth dimensions 700x700
    Basic:
    Asus P8H67-I Deluxe
    Intel G440
    Elpida 2x2Gb DDR3 1333
    Asus 9800 GT Matrix
    EK water bloks
    CoolerMaster V700
    CoolerMaster Eisberg 120l
    Work Pic's
    https://drive.google.com/drive/u/0/#folders/0B1qbbv_BAygGQ21Bb3ZqeHRCV28
    bye
    GP
  19. jbfem
    22 Jan 2013
  20. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Awesome! Congrats on finishing it. It looks VERY solid!
