Modding Case Gallery - Pimp your mod! *Read rules before posting*
Discussion in 'Modding' started by cpemma, 30 Dec 2005.
  1. King Modding
    King Modding What's a Dremel?
    15 Apr 2016
    My Build.
    Eternity
    kim likes this.
  2. GeorgeK
    18 Sep 2010
    Looks awesome :) Helpful hint - when using imgur to host images, you need to use the direct link option (with .jpg or whatever file type you're using at the end) rather than the Image Link. I've fixed it for you this time :thumb:
    Cheers
    GK
  3. socolate
    socolate What's a Dremel?
    25 Dec 2011
    Project I-A-K
    Spec:
    CPU: 2 x E5-2678 V3 ( total 24core 48thread 2.5Ghz )
    RAM: 8 x 32GB DDR4 ECC REG
    VGA: 2 x TITAN X
    SSD: M2 256GB Plextor M6e
    PSU: EVGA 1000W 80 Plus Titanium
    CASE: cnc
    Full water cooling
  4. socolate
    25 Dec 2011
    Project: TUBELESS
    Spec:
    CPU: 2 x E5-2696 V3 ( total 36core 72thread )
    RAM: 8 x 132GB DDR4 ECC REG
    VGA: 2 x TITAN Z
    SSD: M2 512GB Samsung 950 Pro
    SSD: PCI-E Intel 750 400GB
    PSU: Seasonic 1250W 80 Plus Platinum
    CASE: TT Core W100
    Full water cooling
  5. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    My build theme was inspired by legendary PORSCHE 917. The only Gulf Porsche 917 to win the 24 Hours of Le Mans was the one driven in Steve McQueen's "Le Mans" movie. If you're a motorsports enthusiast, I highly recommend seeing this movie for vintage racing footage alone. The story line stinks, but it's really about the event and cars. There is an HD version on YouTube. Many innovations in cinematography were created while filming this movie. Steve's production company welded brackets to the front frame work of the 917, so they could mount a camera to shoot him, and the other drivers.
    The OC-FORCE motherboard has north and south bridge water block by EK. The EVGA 960Ti cards have Koolance water blocks with back plates. The black acetal block tops and back plates were painted the Gulf Racing blue. The Bitspower dress-up pump cover was painted orange. The four Corsair Vengeance DDR (32GB) heat spreaders were painted to match later the theme later. A lot of people asked how I painted them, so I created a video guide for dismantling and painting your own DDR heat spreaders here,
    Staying with the race car theme, I chose 1/2" O.D. Stainless Steel tubing was inspired by the fuel and brake lines of a race car. I used 316 Marine Grade Stainless, so corrosion isn't an issue. Working with Stainless Steel tubing requires a Mandrel bender and lots of practice. It takes a great deal of practice to get the perfect bends. I always keep my water loops simple for easy maintenance. I only use distilled water and change it every 6 ? 8 months. I may use Mayhems Dyes when using clear PETG tubing to accent a color theme in other builds. I?ve been DIY liquid cooling for past decade and find most cooling additives or radiator cleaners are gimmicks and a waste of your money. Just use distilled water and be diligent about cleaning your loop. The water pump is an Alphacool VPP655 with adjustable speed. It has a Bitspower dress-up kit. The pump cover was painted to match the exterior paint. Did you notice that my loop has no reservoir? I like my builds simple and clean. I have a Koolance bleed valve on top of the SLI bridge for filling the loop. I fill the loop through a Koolance 3-way splitter fitting with fill port on the top of the 360mm radiator. Beneath the PC is a Koolance Drain Valve. All I have to do is connect tubing to the drain valve and drain the loop into a bucket next to my workbench. The front grill is 1/8? thick cast acrylic that was laser cut into honeycomb. The top of the case has a smoked acrylic "moonroof" window. The clear side panel has embedded magnets. Both of these window panels are made by Mnpctech. It allows you to look into the PC from above. It has a machined aluminum 120mm ring / fan grill that emulates a fuel fill port on a race car. The ring has blue anodized washer with socket head screws. The rear fan grill is machined aluminum 120mm "Overkill" Ring. All of the fans are Scythe Gentle Typhoons AP-15. Part# D1225C12B5AP-15, 1,850 rpm, 28 dBA @ 57.68062 CFM. Unfortunately these cooling fans are no longer made by NIDEC SERVO, but there is still some available from online retailers. Dazmode sells similar version called the ?DarkSide Gentle Typhoon Performance Radiator Fan? They have good static pressure and under volt nicely. You can easily dismantle them for custom paint.
  6. BU5H W00K1E
    BU5H W00K1E Minimodder
    18 Nov 2017
    My project i just finished called VUE 71
    Started as a thermaltake view 71 case! Also don't mind the walls been slowly doing drywall and gonna be patching and painting them soon.
    [​IMG] [​IMG]
  7. mnpctech
    21 Apr 2003
    metro exodus pc build with cheapskate
    Dot_Kappa, kim and MLyons like this.
  8. Kostas1232
    Kostas1232 What's a Dremel?
    29 May 2019
    My very first scratch PC case built in 2 weeks from almost nothing but aluminium profiles and M5 screws.
    Yes, that's shoelaces holding GPU horizontally
    I am sorry, but I don't have any build log or something like that, so... there's a link to my Imgur gallery:
    https://kostas1232.imgur.com/all
  9. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    This was going to be my shoestring budget pc, went a little overboard, little backstory my FX machine's video card popped (a XFX Double D 7950) and they had a warranty, in return I got a RX570 4gb model, which at the time was still more expensive than it was worth, so I started garage selling stuff on ebay and ended up with a budget machine, though I went overkill on the CPU cause I cought it on black Friday
    3200Mhz Corsair Vengeance LPX ram 2*8GB
    MSI B450 Gaming + Motherboard (uATX)
    AMD Ryzen 2700X (total overkill but I do a lot of cad and software compiling)
    XFX RX 570 OC factory overclocked, runs hotter than a ...
    HP EX920 NVME SSD (512 gig backed up by a 1tb segate 3.5 inch drive)
    EVGA supernova G3 650 watt gold psu
    3x deepcool RF120 fans
    Coolermaster liquidmaster 120 lite rgb AIO
    Coolermaster q300l Case
    Generic DVD Drive
    Computer is tubbed out in plexi and modded to house a slimline "laptop style" dvd rw drive cause I still have a pile of software on that format, hidden cables IS a major focus for me on most my builds.
    20190407_133004.jpg 20190407_133036.jpg 20190407_133201.jpg 20190407_133247.jpg
    Thanks for looking from a part time hobby builder
  10. Lukahai
    Lukahai What's a Dremel?
    21 Jul 2019
    Project BP-WD SN750
    Full Image: Link
    Specs:
    ▶️ CPU Intel Core i9 9900K
    ▶️ MAIN Asus ROG STRIX Z390I - GAMING
    ▶️ RAM Corsair DOMINATOR RGB 16GB
    ▶️ SSD WD BLACK SN 750 500 GB M.2 NVme
    ▶️ SSD WD BLUE 500 GB SATA
    ▶️ VGA ASUS DUAL EVO - RTX 2060
    ▶️ CASE CUSTOM BY BPSTORE
    ▶️ PSU CORSAIR SF 750
    ▶️ EK CPU BLOCK
    ▶️ EK EADIATOR
    ▶️ EK FAN RGB
    ▶️ EK FITTING
    DSC_6400.jpg DSC_6428.jpg DSC_6446.jpg DSC_6467.jpg DSC_6471.jpg DSC_6474.jpg
    Osgeld likes this.
  11. CustomRigs
    CustomRigs CallMeCleaner
    8 Dec 2017
    Just a vid from my NO RGB build :D
    The_Crapman and adidan like this.
  12. orbitalwalsh
    orbitalwalsh What's a Dremel?
    10 Dec 2015
    ATX in ITX case :)
    work in progress
    getting there
    Osgeld, adidan and goldstar0011 like this.
  13. malccy72
    malccy72 Minimodder
    9 Jan 2005
    Thank goodness for Lego eh. Good build.
  14. Osgeld
    Osgeld Minimodder
    9 Jul 2019
    Nintenputer
    20190621_212214_HDR.thumb.jpg.8e11a4fb7b2fd7667ea9b83f1afff675.jpg 20190621_212343.thumb.jpg.dfae79e174630e6834a194c19ded25fa.jpg 20190621_212412.thumb.jpg.1b2099d84766cacd21e1f085ee351453.jpg 20190621_212856.thumb.jpg.7a2bde55de4875e66da1aabbb1f51781.jpg 20190621_213619.thumb.jpg.27da4bada4fbe3854b3384933cf10f13.jpg 20190621_213739.thumb.jpg.03892d79c022b3c30c86b7d2a53fc366.jpg
    which is headed to its new home in Canada
  15. scooby
    scooby Minimodder
    3 Mar 2004
    I can't believe it's taken me 10 years to post back on this thread. My how time fly's. Here is what I've been working on since.
    The Rig....
    Case: Corsair Obsidian 1000D Super-Tower
    Motherboard: ASUS ROG RAMPAGE VI EXTREME
    Processor: Intel Core i9 7980XE
    Memory: G.SKILL Trident Z Royal 64GB 3600Mhz
    Graphics Card: NVIDIA GeForce RTX 2080 Ti Founders Edition (x2) NVIDIA GeForce RTX NVLINK Bridge 3-SLOT
    Power Supply: Corsair AX1600i Series, 1600 Watt
    Operating System Drive: Samsung 970 PRO NVMe Series 1TB M.2
    Data Storage Drive: Samsung 970 EVO NVMe Series 2TB M.2 (x2)
    Operating System: Microsoft Windows 10 Pro
    Cooling: 28 Fans and some H2o
    ....and the Setup V2.0
    At the base of all this is a Driving/Flight Simulator that happens to morph into an All-In-One Work Station. All that without getting out of my seat. I know I'm a lazy old fart but that's what made this build so much fun for me. I guess a short Setup spec list is in order.
    Monitors:
    LG 43UD79-B 43" (x3)
    Desk/Sim Rig:
    UPLIFT 2-Leg Height Adjustable Standing Desk
    SimLab GT2 Simulation Racing Chassis
    Ergotron WorkFit-P Sit-Stand Workstation (X2)
    Wheel/Pedals/Joystick:
    Fanatec ClubSport Wheel Base V2.5
    Fanatec ClubSport steering wheel Porsche 918 RSR
    Fanatec ClubSport Steering Wheel Formula Carbon
    Fanatec ClubSport Pedals V3
    Fanatec ClubSport Shifter SQ V 1.5
    Fanatec ClubSport Handbrake V1.5
    VirPil VPC MongoosT-50 Dual Stick
    Mouse(s):
    ELECOM M-HT1DRBK Wireless Trackball,HUGE
    3DConnexion SpaceMouse Wireless 3D Mouse
    3Dconnexion SpaceMouse Pro Wireless Professional 3D Mouse
    I'm open to some wireless gaming mouse suggestions, thanks in advance.
    Keyboards:
    LOGITECH G613 Wireless Gaming Keyboard
    Azio Retro Classic Bluetooth Onyx
    In the above image the setup is in the Stand profile. Yes the setup is a "Sit/Stand" workstation too. I mounted the three 43" monitors on a UpLift motorized stand with a 355lbs weight capacity....very cool huh! Now I wish it can make me a Cheeseburger I'd be set. The stand also houses the PC* behind the monitors and as an added plus the whole thing are on UpLift's very heavy duty wheel casters*. Very convenient, monitor/PC can go up or down and all around all with one hand.
    *The PC and casters not shown on these pics they were added so after.
    In the end I built it to make me happy doing the things I love. Thanks for viewing and I hope your dreams (with hard work) will come true like mine did.:cool:
  16. Cheapskate
    13 May 2007
    @scooby - I see why you went missing now. Sweeeeet rig. I thought those arm rests were stirrups in the first pic, though... :worried: I guess they could be used for that too.
  17. scooby
    scooby Minimodder
    3 Mar 2004
    @Cheapskate, Hey my friend good to hear from you. Funny I get that a lot "stirrups". Your the first to mention they are armrest, but yeah my girlfriends thinks it fun too.:grin: Good to know your still rocking & a rolling.:rock:
  18. The_Crapman
    5 Dec 2011
  19. CustomRigs
    8 Dec 2017
    I hope you like it :)
    Moving pictures :D sorry !
  20. MADPC
    MADPC Minimodder
    10 May 2020
