Modding Case Gallery - Pimp your mod! *Read rules before posting*
Discussion in 'Modding' started by cpemma, 30 Dec 2005.
  1. Colossous
    Colossous Minimodder
    28 May 2007
  2. ranlai
    ranlai What's a Dremel?
    20 Oct 2007
    Tortoise Beetles
  3. ranlai
    20 Oct 2007
  4. Mysterae
    Mysterae What's a Dremel?
    21 Sep 2005
    Parallel Hex
    I should have started this here, perhaps I will when I upgrade it :thumb:.
    This is a 6 loop parallel water cooled PC. AMD 4400+, X1900XTX Crossfire, plus high current laser :duh:.
    Can I please have one more pic, please?! It explains the elaborate plumbing...
    The full worklog with lots of pics can be found here.
    Some random videos of strange goings on with the water cooling in the reservior:
    Video 1 of 6 - Night time illumination, shows the bubbling effect in the Collector.
    Video 2 of 6 - Day time lighting, starts with the Collector effect, then reducing it.
    Video 3 of 6 - Day time lighting, close up of the Collector effect and a general pan.
    Video 4 of 6 - Night time illumination, with the laser being activated.
    Video 5 of 6 - Night time illumination, with the laser being activated (again but longer).
    Video 6 of 6 - Day time lighting, with the collector effect very visible.
  5. MegadetHCl
    MegadetHCl What's a Dremel?
    8 May 2004
  6. Luxorz
    Luxorz What's a Dremel?
    9 Dec 2007
  7. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    This is the Qmicra v2 SFF mod I performed for PCDesignLab.
    I posted video on how to paint black gloss enamel finish with spray paint in bit-tech Guides
  8. bobdahaxor
    bobdahaxor What's a Dremel?
    1 Jan 2008
    My first mod
    I took my cooler master stacker, added a window, put a green cathode, got a giant thermaltake copper tower, got some cool fans, tucked away all the cables and this is what it is at now. I know it is not much and ya'll probably laugh at it, but here it is and please critique and gimme some good ideas to mod it further and make it look better (please no water cooling or something that is outrageously expensive) Specs: AMD Athlon 64 3500+ @ 2.42Ghz, Asus A8N5x mobo, 2Gb DDR400, eVGA 7800GT @ 495core and 1222mem, DVD drive, DVD-RW drive, 500watt Thermaltake PSU
  9. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    The Purple Dragon Project
    My first and only mod (so far).
    Case: Chieftec Dragon DX-01PL-D-U
    Select key features:
    - Inside painted flat black and all unnecessary interior items have been removed.
    - Four 80mm fans mounted in the front in a custom mounting plate.
    - Top and side window created using dark tinted acrylic.
    - Top window has a recessed fan controller w. LCD display.
    - Also in the top window is a key that needs to be turned for the PC to be switched on, and a Bulgin button.
    - And lots, lots more - check the log.
    Link to log (2nd page with pictures of the completed mod): The Purple Dragon Project
  10. HaoKi
    HaoKi Lleno de anguilas!
    10 Oct 2003
    The Eutanasia-Project
    Here's my completely custom built gaming rig. :)
    The case was designed and built to be small and durable. It has the dimensions of an matx-case but it still houses a full-atx system.
    It has watercooling for the CPU and enough space to fit SLI into it. In addition the case itself hardly restricts the used components.
    Project: Eutanasia on Metku.net
  11. robyholmes
    robyholmes I'm under your desk...
    17 Jan 2008
    Lian Li
    By Rob Holmes (robyholmes)
    Slideshow
    Spec:
    Core 2 Duo E6400 2.13Ghz @ 3.1Ghz
    Cosair Dominmator 2Gb 1066Mhz
    Asus P5E x38
    EVGA Geforce 8800 GTS (Super Overclocked)
    320Gb SATAII
    DVD-RW SATA
    Coolmaster 600W blue sries
    Lian Li V1100B Plus II
    OS:
    Vista 32Bit
    Ubuntu 7.10
  12. rchiileea
    rchiileea Minimodder
    11 Jan 2008
    Mod was called fusion AA (to represent the fusion of amd and ati) all the panels apart from io were custom made by us. all the etching on this case was also done by hand and using the dotinism technique.
    http://www.xtremecomputing.co.uk/images/mods/FusionAA/FusionAA/FusionAA_41.jpg
    Link to large pic of the spider etch on the mobo back panel
    Roof etchings
    http://www.xtremecomputing.co.uk/images/mods/FusionAA/FusionAA/FusionAA_31.jpg
    http://www.xtremecomputing.co.uk/images/mods/FusionAA/FusionAA/FusionAA_30.jpg
    Main panel etch (the best imho)
    http://www.xtremecomputing.co.uk/images/mods/FusionAA/FusionAA/FusionAA_24.jpg
    http://www.xtremecomputing.co.uk/images/mods/FusionAA/FusionAA/FusionAA_13.jpg
    [url]http://www.xtremecomputing.co.uk/images/mods/FusionAA/FusionAA/FusionAA_15.jpg[/url]
    The log is [URL="http://www.themodnation-forums.com/viewtopic.php?t=2217"]here[/URL]
    souper82 likes this.
  13. Syrillian
    Syrillian What's a Dremel?
    13 Feb 2008
    Custom acrylic case
    Dual liquid loops, horizontal motherboard, separate thermal zones.
    Halcyon:
  14. mnpctech
    21 Apr 2003
    PR Tribute PC Worklog Link
    Watercooled Intel / Tyan Server one side, Watercooled AMD / DFI SLI Gaming system on the other.
    The cards, memory and HDs are being installed by somebody else.
  15. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    Fully log [THREAD=1623460]here[/THREAD]
  16. megadega
    megadega What's a Dremel?
    15 Mar 2008
  17. Americanfreak
    Americanfreak What's a Dremel?
    25 Aug 2005
    Check out more here at Modders-Inc
    (To the post below...Sorry, dang hotlink blocking. You should see the images now and those links are dead. -AF)
  18. mnpctech
    21 Apr 2003
  19. willowthewhite
    willowthewhite Minimodder
    7 Nov 2006
    Antec P182
    Full work log Here.
  20. Koradhil
    Koradhil What's a Dremel?
    9 Nov 2004
