Modding Case Gallery - Pimp your mod! *Read rules before posting*
Discussion in 'Modding' started by cpemma, 30 Dec 2005.
  1. alidarkstone
    alidarkstone What's a Dremel?
    24 Dec 2009
  2. wE-eViL
    wE-eViL Sparky
    19 Dec 2009
    Banchetto
  3. zAAm
    zAAm What's a Dremel?
    10 Jan 2010
    mediaBIN3.0 Weighted Companion Cube
    Description: The Portal Weighted Companion Cube recreated in all its SFF glory at 230mm cubed. Almost perfect replica with custom made LED strip lighting on ALL sides. Atom 330 powered.
    Project log: http://forums.techpowerup.com/showthread.php?t=108257
  4. Blarte
    Blarte Moderate Modder
    15 Jul 2008
  5. modscases.com
    modscases.com What's a Dremel?
    29 Oct 2009
  6. AT0MAC
    AT0MAC Pirate Captain
    8 Jun 2008
  7. swaggahurtz
    swaggahurtz 2 c not what is but what can be....
    24 Feb 2010
  8. swaggahurtz
    24 Feb 2010
  9. GreenRay
    GreenRay What's a Dremel?
    9 May 2010
    MoneyBin:
  10. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
  11. mnpctech
    21 Apr 2003
    Corsair 800D Obsidian case we did for HWC
  12. jaseuk
    jaseuk What's a Dremel?
    10 Apr 2010
    As I'm new to the forums I thought I'd pop a couple of pics up of my rig
    that reminds me I still need to mod the power supply cables to gpu
  13. mrdbristol
    mrdbristol Voided my warranty years ago
    8 Aug 2008
    Javerh likes this.
  14. Toasti0
    Toasti0 What's a Dremel?
    23 Mar 2010
    This is my first case mod ever and after having a black box with fans in it for so many years I decided to try something different mix it up and I figured the coolest way to make a pc stand out is to put it inside of a 18'' Alloy wheel.
    Specs are i7 920 @ 4.0 ghz+ (1.24v D0 stepping) , 6 gig 1600 mhz xmp memory 1 x 360mm and 1 x 120mm radiator 4 120mm smart fans. ATI 5770 now in crossfire. Raid 0 2 x Samsung f3 spinpoints.
    http://forums.bit-tech.net/showthread.php?t=185177&highlight=wheely
  15. Batiatus
    Batiatus What's a Dremel?
    25 Jun 2010
    Project Dark Serenity
  16. Fusionmkx
    Fusionmkx What's a Dremel?
    14 Jan 2009
    Hey guys, just wanna share my latest rig. Project envisioned in 2009, finally complete in 2010.
    The Platinum Box.
    [Components]
    Processor: Intel i7 920 @ 3.4Ghz
    Motherboard: EVGA x58 SLi
    Ram: OCZ 6Gb 1333mhz DDR3 Tri-Channel
    Harddrives: 2x 2TB WD Green, 1x 1TB WD Green
    Graphics: Nvidia GTX280 1Gb
    Chassis: Lian-Li A05N Silver
    [Cooling]
    CPU: Watercool.de HEATKILLER3.0
    NB: Koolance x58 Northbridge waterblock
    RAM: OCZ Silver heatspreaders
    GPU: EK Fullcover GTX280 Nickel-plated waterblock
    Radiator: Swiftech MCR360 Radiator
    Pump: Swiftech MCP355 18watt with XSPC top
    Fans: 3x Evercool Aluminum Fans, 1x Enermax Apollish
    Fan Controller: Scythe Kazemaster ACE Silver
    Tubing: Tygon Lab-grade R3603 3/8" tubing
    Fittings: Bitspower fittings and attachments
    Enjoy~
  17. forester joe
    forester joe shhh. can you hear your PC?
    24 Oct 2005
    nice
    any work log on this?
    especially interested in more details on the Hard Drive cage.
  18. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    EDIT: missed that rule, my fault, late night, please delete.
  19. Fusionmkx
    14 Jan 2009
    @Forrester, thanks! Project log here:
    http://forums.vr-zone.com/project-logs/824790-project-log-fx-the-platinum-box.html
    As for the HDD drive, the HDD rack is secured into both fans. Yes it IS a Lian-Li cage taken from another casing, the legs at the end of the bracket fit just nicely that the 120mm middle fan at the bottom is unimpeded. The two edges of the HDD bracket sit ontop of the ends of the two front and rear fans. In my original design I bored two holes at each end intending to secure the cage to the fans, but after installing, I realized I couldn't reach the internal screws. (front blocked by PSU), rear blocked by HDDs jutting out. (Didn't manage to envision that problem!)
    So the holes in the cage and the bored holes into the fans were not used in the end. In the end I just secured the cage with 3M industrial clear tape. (3m VHB), this tape is amazing, it's clear, ULTRA STRONG, and thick enough that it has some sort of vibrational isolation. The tape peels off cleanly and is so strong, when I tilted the case nearly upside down to bleed the loop, it held on with no issues. The idea was to have SOME sort of airflow over the HDDs, hence also the design consideration to put them there. In many A05N rigs, the HDDs are usually placed in the single 3.5" bay if the HDD cage is taken out, but there's no ventilation over that area and I am not keen on only putting one drive.
    Here's a centre shot.
    All the fans are all rubber-rivet isolated (rear 120mm fan has grommeted screws. More pics for u guys on how I put rubber rivets into the radiator.
    Not sure if posting this is appropriate here, but hey great to share.
    Hope you guys like my rig!
  20. cornelious0_0
    cornelious0_0 What's a Dremel?
    1 Jun 2010
    What used to be a Shuttle SP35P2 Pro...dead until I can justify replacing the mobo/PSU. :(
