Case hunting
Discussion in 'Hardware' started by DarkReaper, 13 Jan 2004.
  1. DarkReaper
    DarkReaper Alignment: Sarcastic Good
    9 Jan 2004
    Can anyone help me with a UK source for the Enermax CS-56881LBFS-OY? I can't seem to find it anywhere and am starting to get fed up.
    Any help greatly appreciated
    Moved to Hardware
  2. Trickle
    Trickle What's a Dremel?
    14 Dec 2003
    Its a JNC (or Jeantech [sp?]) painted yellow. Ebuyer sell them. I bought one last year for about £45 ish inc 350W psu.
    Build quality is perhaps a tad better than I expected for that price point... though expectations were at rock bottom, so could really only go up. They even included a stobe light not mentioned in the spec... which was naff, but doesnt need to be on.
    Still have an old piccie here. Case now sold. Not too bad for the price tbh - but still an el cheapo pre-mod case at the end of the day.
  3. Trickle
    14 Dec 2003
  4. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    tbh, it looks like all the other premods that you get in pc world/maplin. pick one up from there and spray it to you colour of preference.
    edit: it is the same chasis as nearly all the premods i've seen, its just the front panel thats different.
  5. DarkReaper
    9 Jan 2004
    It was actually the sliding blanks at the front i liked it for... plus the colour, but spraying it myself seems slightly daunting.
    Ah well, double-windowed Icute at maplins for £40, can't be too bad
  6. BRIMCV
    BRIMCV What's a Dremel?
    23 Nov 2003
    I have that case on ebuyer except the front is slightly different. I wouldnt recommend this case as there is space for only one 80mm exhaust and it gets a bit messy inside.
  7. Xen0phobiak
    8 Aug 2002
    sprayings no problem if you take your time, use a plastic primer, do thin coats, sanding any imperfections with wet-and-dry as you go. leave the case overnight after each coat before the next one/sanding. about 3 coats of primer, 3-4 of paint and 1-2 of laquer :)
  8. DarkReaper
    9 Jan 2004
    Bit of a bugger when theres tinted acrylic on the front of the case and two windows, though. Maybe I could remove it... or just mask it with tape
  9. Xen0phobiak
    8 Aug 2002
    it all unscrews :D
  10. DarkReaper
    9 Jan 2004
    w00t :D
    Now i need to find a cheap mobo, psu and all the other parts to shove into my old case and start a computer farm :dremel:
  11. Xen0phobiak
    8 Aug 2002
    thats the way, just like i did :D :D
