Case Mod - In Progress Case Labs ST10 Project "HardLine"
Discussion in 'Project Logs' started by HammerForged, 18 Jan 2013.
  1. HammerForged
    HammerForged New Member
    10 Nov 2012
    Oh gotcha! Mine just came with it. After doing a little research I found basically 3 revisions to the product. This a typical thing for Koolance. Instead of making a new product number they just update it.
    Here are the other two revisions:
    Thanks for the nice comments! The price may seem high but like you said it really is a case for life!
    p0Pe likes this.
  2. Skeng
    Skeng Water Cometh!
    27 Jul 2010
    Ah ok I've probably got a different revision then :(. How are those corsair fans for both noise and cooling, I'm thinking of switching to them but I don't want anything too noisy.
  3. HammerForged
    10 Nov 2012
    They are some of the best static pressure fans out right. If you have the ability to run them on a fan controller they are pretty quiet. I have 20 :eeek: in this build and it is pretty reasonable. I mean you'll know its on but not by much.
  4. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    They are the same revision,just one has a the vertical mount fitted,they changed the design as the pump used to pop out of the top....it happened to me,I had the version 2 come back as a replacement
  5. HammerForged
    10 Nov 2012
    Just a little bit of an update.
    Ordered up some inverterless red cold cathodes. Got a tripod coming as well so I can hopefully take some decent pics.
    Looking for some ideas to cover up the ugly PSU support bar shown below. Any thoughts or suggestions shoot em my way. I was originally thinking about getting a black vinyl sticker made up with CaseLabs and project Hardline on it. Having a hard time sourcing someone to make this though.
  6. HammerForged
    10 Nov 2012
    What do you all think of this for a vinyl going up the PSU support?
  7. HammerForged
    10 Nov 2012
    Finally took some time and took some final pics! I have very poor photography skills but hopefully these can represent all my hard work.
  8. Yaka
    Yaka Well-Known Member
    26 Jun 2005
    that looks brilliantly neat, and like i said before those pipes are awesome
  9. HammerForged
    10 Nov 2012
    Thank you very much! :D
  10. tekonivel
    tekonivel Member
    14 Jul 2012
    Really good work. You Kept it nice and clean.
  11. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Love those cases and love the job you have done on it.
  12. HammerForged
    10 Nov 2012
    Thank you all :D
  13. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    totaly awsome my friend!
    You should be proud of the build !
  14. HammerForged
    10 Nov 2012
  15. Asouter
    Asouter --------
    18 Jan 2012
