Modding Case moded with the help of other members.
Discussion in 'Modding' started by Vittorio, 2 May 2002.
  1. Vittorio
    Vittorio What's a Dremel?
    30 Apr 2002
    Well after some more work and time with a paint can, I have finished my first stage of modding. I have taken the comments other members have given and put some of them to use.
    [​IMG][​IMG] [​IMG] [​IMG]
    The only problem I found was that with polishing my case internals the light reflects a little to much for the camera.
    Now all I have to left to add is a nother cathode in the bottom of the case and probably some neon round the front of the case. I am also waitting for my other side panel now to be returned with the airbrushed art work added. I also have to finish the design that i am going to have made for a window etch.
    Here's a look at the art work for the side panel
    I must also just add that Kustom Pc's we so quick at sending me out the parts i ordered. I got everything next day.
    Thanks to all the other members who inspired me into this mod and have started something. I will be modding some more cases very soon and maybe even build one from scratch.
  2. LoopyJuice
    LoopyJuice Astronomical
    24 Jun 2001
    lookin sweet :D although i have my drives in my lian stealthed and IMO they look a lot better than sprayed, i have nothing on my front bezel, the floppy is internally mounted behind the blanking plate, u have to take the plate out to use it but i never do anyway and i jsut have lil 1mm holes with fibre optic cable to display the leds on cdrom / cd-rw drives :) i'll post pics when i can.
  3. Lazy
    Lazy Meow?
    13 Nov 2001
    cool, you sprayed the floppy all black, i wonder which smart person thought of that? I wonder.....
    If you want to imporve it further then you might want to invest in a uv cathode and paint all your fans with uv reactive paint because it looks very cool.
  4. WhyPush
    WhyPush What's a Dremel?
    22 Apr 2002
    And it DOES look so much better with the painted rivets, don't you think? :D
    Do we have egos or what!?!?!?
  5. Vittorio
    30 Apr 2002
    Yep you both were right, the floppy drive does look better all in black and yes the rivets do look better black.
    Though I must say I have now hidden the floppy drive because i do not use it that much.
    My next task is going to be to paint the fans as per the article on the site.
