Electronics case monitoring devise.. any help on design?
Discussion in 'Modding' started by Springs, 16 Oct 2004.
  1. Springs
    Springs Boing boing
    29 Aug 2004
    i was woundering about making one of those DC meters to monitor tempreture in my case... can any 1 reccomend what i need to do :D
    i found a 5A DC Meter that has the sort of display i want... as in it shows a blue curve going onto a red one... i was going to use something like a Thermistor to "gather" the heat... so to speak.. and if possible a couple of LED's to show when its ok and when its getting hot..
    any help?
  2. infernis
    infernis What's a Dremel?
    5 Jan 2003
    Well, you could use a thermocouple,
    http://www.picotech.com/applications/thermocouple.html
    and then an op-amp in a comparator configuration. Basically, a comparator compares the voltages of the two inputs and sends the appropriate supply voltage to the output. If the voltage at the inverting input is higher, the negative supply voltage is sent to the output, and if that of the non-inverting input is higher, the positive voltage rail is sent to the output. You might want to brush up on op-amps if you don't understand what I'm saying.
    The key here is to have a reference voltage at one of the inputs. The other input comes from the thermocouple. If this voltage is higher than the reference voltage, the output reflects this. At the output side, you could have two LEDs, one opposed from the other--so tie the cathode of one to the anode of the other, and the anode of one to the cathode of another. When negative voltage is applied at the output, one LED--the reverse-biased LED--turns on. When positive voltage is applied, the other LED turns on. As for your temperature measuring instrument, I'd need more information to help you.
  3. Skylined
    Skylined Minimodder
    3 May 2003
  4. Explicit
    Explicit What's a Dremel?
    23 Dec 2002
    Device
    Wow, spelling is hard.
