Modding Case Painting Question
Discussion in 'Modding' started by Fatboy, 3 Apr 2002.
  1. Fatboy
    Fatboy Bored
    8 Oct 2001
    I have had my case apart for the last couple of days painting it black . Ihave put the primer on after sanding and have waited and painted all black, i didnt sand because im not after shiny finish. Should i put clear coat on now because i cant really be bothered to go and get some? im not after a long lasting finish cos i will change cases later in the year but im wondering if i should clear coat it.
  2. Splod
    Splod What's a Dremel?
    9 Dec 2001
    i think you need to , not entirely sure, when you say not a smooth finish do you want something like those lian-li's??
  3. Fatboy
    Fatboy Bored
    8 Oct 2001
    I mean that im not after a mirror finish as the case is black and i cant be bothered with the sanding and rubbing compound
  4. Splod
    9 Dec 2001
    no mate a black case with a mirror finish is on of the best looking things i've ever seen!!!
  5. linear
    linear Minimodder
    5 Oct 2001
    You can skip the clear coat. Your last coat will continue to harden for about a month before it reaches its maximum resistance to scratching.
