Cases Case where the traditonal back points upwards?
Discussion in 'Hardware' started by adzc1987, 7 Oct 2011.
  1. adzc1987
    adzc1987 Minimodder
    19 May 2011
    Hi all, im looking for a case that has the MOBO rotated 90degrees (i.e. the fans blow air upwards).
    I know silverstone do some cases like this but is there any other out there? Is there a particular name for these type.
    I like the idea and would like a case like this, preferably spending no more than £50
    Cheers
  2. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    There are others, but afaik the Silverstones' are the cheapest weighing in at between £150 - £200. You could try looking out for a second hand RV01 or RV02 if you're on a budget?
    TSB
  3. adzc1987
    adzc1987 Minimodder
    19 May 2011
    Yea they aint cheap, any particular name for this type of case, im not havin much luck finding other brands.
  4. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    As STB said Look at Silverstone is possibly the cheapest I don't think there is a specific name for that type of case, google for Computer cases with 90 degree mobo's!
  5. adzc1987
    adzc1987 Minimodder
    19 May 2011
    Yea but im not shelling out 150 on a case, i just thought there may be other companys but im not having much luck trying to find any.
    Ill just need to go for a "normal" case, probably the antec 100
  6. Telltale Boy
    Telltale Boy Designated CPC Jetwhore
    3 May 2010
    The least you'll be spending is just over £100 on a Silverstone FT03 or RV03. All of Silverstone's cases are great quality though and well worth the money.
  7. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Trust me spending the money on a decent case is worth it, I was going to go with a mid range case till I was told of the benifits of the one I have now. I paid £100 or so for mine, and whilst the fans make some noise the cooling it does is epci!
  8. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    I thought I was brave spending £80 on a fractal r3 until I saw people on here with £200 cases... Then modding them :dremel:
  9. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Thats because those guys are hardcore. I am not even entertaining doing anything to my case. I am thinking of swapping the standard 932 front/side and top for the nVidia Green versions xD
  10. longweight
    7 May 2011
    The FT02 is awesome :) I love mine!
  11. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    A good case you upgrade rarely, a amazing one you never upgrade...
    MrDomRocks likes this.
  12. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Exactly +1
  13. adzc1987
    adzc1987 Minimodder
    19 May 2011
    Mmm well its just im not doing a complete overhaul atm, im gonna save for a good while before i splash out. Then ill probably get a decent one, just cant afford shelling out that much atm XD
    The antec should do, my current case is really showing its age.
