Case Mod - In Progress CaseLabs MAGNUM M8K
Discussion in 'Project Logs' started by kier, 18 Mar 2012.
  1. kier
    kier -----------------
    1 Mar 2011
    Today the start of a new build with a super case: the CaseLabs Magnum M8 Labs
    Sponsored by...... CaseLabs, Lamptron, Highflow, Coolermaster and EKWB
    First my thanks goes out to Jim (CaseLabs) for providing this beautiful case
    Received this beautiful gift on my birthday
    Offcourse unwrapping it right away
    Once out of the box
    One of the finest cases I've ever seen, quality is superb
    And with an XL window on the right side
    And also on the left side
    After admiring the outside for some time, the inside
    With 3 HDD cages
    Attached with screws and rubbers
    Pins to hold everything in place
    With two vertical accessory mounts
    Once everything is removed there is a lot of space for a nice WC setup
    Other side also perfect quality
    Place at the bottom for a 360 radiator
    Passages for tubes and / or wiring
    8 Slots is enough
    And enough space for various purposes
    Also with a Horizontal Accessory Mount
    And included 2x Lamptron switches which also perfectly finished
    Already sleeved
    The windows also very nice and simple mounted
    Nothing pasted or with bent strips, but with nuts
    So always easy to exchange if necessary. After damage or any other acrylic color replacing. Clamping mechanism is also well thought
    This is also applied to the front and top panel, which is also removable
    Space for 3x 120mm fans
    But that's not all. There was another package
    Quickly unwrapping it again
    And it is the extended pedestal, for all your radiators and other stuff
    At the back holes for 2x 140mm fan
    So much space inside, but I choose for a bracket for 2x 360 radiator
    The front also has a removable panel. Always nice to mod
    So the extended pedastal. Lots of extra space, a real nice addition
    Once installed everything, I was shocked
    Really big
    Some more pictures of the beautiful extra addition
    So a new build with a superb case from:
    :clap:
  2. SilveR_172
    SilveR_172 Minimodder
    24 Nov 2011
    going to me Modding this too mate ?
  3. Shurika
    Shurika Minimodder
    9 Mar 2012
    Huge case! What are you going to do with it, except installing the water-cooling? Will you use some more colours on it`s exterior? Of cource subbed! MBK - always top modding!
  4. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    STEP AWAY FROM YOUR CASE, AND PUT DOWN YOUR DREMEL! :lol:
    There is NO stopping you, huh Kier? :)
    I smell a cat-right with pOPe on this, can't wait to see how you're gonna do this one! :thumb:
  5. kier
    1 Mar 2011
    Lol, sorry I cant. It is stuck to my hands :dremel:
    p0pe is the Caselabs guru :jawdrop: so I will and cannot compete with him
    But I will do my best with this case :thumb:
  6. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    you are a modding machine:rock::dremel:
    Subbed
  7. jhanlon303
    7 Sep 2006
    Start of another work of art. Subd
    john
  8. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Look forward to this!
  9. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    This is going to be mega!! Another Kier mod with a sublime case and sooo many possabilities.
    Not only could it be the pesestal but you could use it for the top instead and put some awesome screen in that front space!
    Then again im sure you got this one all planned out already ;)
  10. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Autosubbed (if that was possible....hey, why isn't it possible???)
  11. kier
    1 Mar 2011
    Thanks :thumb:
    Thank you John
    :clap: me too ;)
    I....like the idea ;) :clap::clap:
    Dont know, never tried it :)
    Before we even get to modding, an overview of all the accessories
    One Standard HDD Cage is coming with the case
    Ordered two more
    As I mentioned earlier comes with rubber bands for installing at the front with screws
    With gaskets and mounting bolts for the HDDs
    The SSD Mounting Kit
    Two Vertical Accessory Mount
    And the Horizontal Accessory Mount
    These will be very useful
    A PSU Support Bracket For heavy powersupplies
    A lot of Flex-Bay Device Mount
    Two x 360 Radiator Side Mount For in the pedestal
    And a Bottom Accessory Mount
    To replace the standard bottom covers, consists of three sizes (picture is the longest)
    A few HDD Opening Cover Plates Replacement cover plates for the HDD openings on the PSU side
    A Large Attachment Plate for various purposes such as installing reservoirs or miscellaneous
    And finally, all the spare parts comes with the case
    Of course I also had time to do some modding. A little teaser ;)
  12. Nutman
    21 Oct 2008
    Well, I WAS sitting here thinking "Yeah, yeah - nice HW, but WHERE'S THE MODDING?". And then I got a teaser.... sigh
  13. kier
    1 Mar 2011
    Update!!!
    Ok, my friends Its modding time :)
    Beneath the top cover there are holes for 120mm fans, which I dont need.
    These will disappear, because I want a good view from all sides
    So taped and marked
    Always an exciting moment...the first cut-out
    I also slightly modified the recesses in the bottom of the case. There were also holes for 120mm fans (3x) on both sides
    Between the pedestal and the case I have inserted an acrylic plate, which makes the separation between the two
    Later i am gonna use fill ports for the tubes and/ or acrylic pipes
    In the top cover I also made openings ​​with the same size as the recesses underneath
    Piece of acrylic for the top window
    For the front I also did some cutting, but first marking
    The same dimensions as the 5.25 bays
    Piece of acrylic behind
    Going to use the exciting fanholes because of the 360 rad behind it later
    To keep the color combination (black / silver) I have cut a piece of aluminum with the fanholes. And a hole for the switch. This is further extended to the right with displays, and more switches in the middle.
    What's going to look like this
    More to come ;)
  14. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    Kier doing it again :thumb: what hardware is going in this beast??
  15. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Great cuts as always!
    Only thing I'm not sure is about the placement of the 3 holes, they just look too close to the edge... I know that you used the original placement but imho that doesn't look good at all.
    Maybe you could open the cuts a little bit to the sides (on both cuts)?
    Keep modding!
  16. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    one thing about photography. I can see u are useing the light box or something like that but u need 2 tool more it is a gray card and Adobe lightroom or something like that. The problem is you r light. But the case mod i LOVE it very good keep it going.
  17. kier
    1 Mar 2011
    The story continues......With some nice hardware and more;)
    The hardware is a nice Gigabyte mobo: The Z68X-UD4-B3
    And a great CPU: The i7-2600K
    I've changed my mind regarding the front. For this I made the aluminum front again
    The opening above is for 2 HDD coolers. Always fun to see how the flow is
    Made it black
    In order to be able to make this happen, there where some adjustments necessary
    After some dremel cutting and filing
    So I've slightly modified the existing hdd cages and placed it
    And this is how the front looks for now. There also are coming two Lamptrons touch controllers in it
    I also want to thank Cooler Master for providing theTurbine Master Mach 1.8 fans
    And...a beautiful M2 Silent pro 1500W
    He's big....really big :)
    Nice sticker, not unimportant lol
    After placing the PSU I've been playing with the space. And to fill this space I've cut a piece of aluminum and bent it.
    Cut a piece of 5mm black acrylic
    This will be the bottom
    On this I will place two reservoirs, not the 150mm but 250mm
    Left here and there some space for some ideas
    And at the back I've made a fanhole for a nice small 80mm fan
    More to come ;)
  18. Foregasm
    Foregasm What's a Dremel?
    3 Apr 2012
    YEESSS. HE'S BACK. I HAVE BEEN LOOKING FORWARD TO THIS. :D
  19. Nutman
    21 Oct 2008
    I foresee awesomeness in this thread.
  20. kier
    1 Mar 2011
    Sponsor update:
    Lamptron is also helping me with this build, So special thanks to Maurizio
    Received the first touch controllers. I asked for aluminum version (which is convenient for future builds) but for this build I'm adjusting these.
    Specificaties:
    Dimension:148.5mm X 42.5mm X 64.5mm (5.25inch bay)
    Screen Dimension:118mm X 31.5mm
    Power Output:Up to 30W per channel
    Control Channels:6
    Included cables:
    6x Temp sensors
    6x Sleeved fan cables
    And a manual, jumper and molex cable
    A very nice sleeve kit...The Modding tool kit
    A great set for the disassembly your 4 and 8 pin EPS (12V), ATX Connectors, PCI-E connectors and more!!!
    Perfect kit
    I also received some switches including 3x 19mm white dot momentary
    And 2x 19mm white dot latching
    Maybe a bit lazy but also ordered
    5x connection cables
    Nicely finished and sleeved
    Couldn't resist to intall the switches
    And with acrylic in front of it. Still need to cut the holes and raise the switches a little bit
    And just one final pic to show the quality of the beautiful finished aluminum faceplate
