Case Mod - In Progress CaseLabs MAGNUM M8K
Discussion in 'Project Logs' started by kier, 18 Mar 2012.
  1. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Nice one - 30W per channel! How about that, Aqua Computer?!?!??!!
  2. kier
    kier -----------------
    1 Mar 2011
    Sponsor update
    I also want to welcome a great sponsor for this build .... Highflow
    Given the great choice of products, I have choosen some nice stuff.
    Always nice to a Highflow package, Thank you Freddy!!!
    First two beautifull reservoirs. The EK-Multioption RES X2 - 250 Advanced
    Some Tygon R3603 - HighFlow - 1/2 ID - 3/4 OD - Clear tube
    And nine great NorthQ 120MM 3711RL Silent Tornado fans
    Also a small 80MM NorthQ 3709RL Silent Tornado
    Playing with the fans ;)
    I'm very satisfied with the fans, They will look perfect in this build
    And last 2x Acryl Paneel - UV Rood / Transparant - 500x500mm
    Once everything unpacked, it's modding time. Cut a piece of red acrylic and cut a hole in it for a tube
    In the black acrylic I have cut 2 holes with the size of the reservoirs cut to keep them in place
    And cut a little piece for a fillport
    Two fillports for the hdd cooler with a little touch of red
    Playing with the tubes and of course placed the fans
    Also placed the reservoirs with some BP links (these will be black)
    After a bit of measuring and other small things, made the aluminum plate black
    And placed everything back
    Again connected the tubes
    And two pics how one side stands now .... on to the next ;)
  3. Saltire35
    Saltire35 Drunken Scotsman
    5 Dec 2010
    Stunning! :rock:
  4. Nutman
    21 Oct 2008
    Hm... I'm quite torn.
    See, all Kier-builds of late have had those dead straight Bitspower crystal links, straight tubing or simply used straight acrylic pipes.
    This one has tubes that bend. I definately have to get used to you now doing what most of us do. ;)
  5. kier
    1 Mar 2011
    I'm still not sure about the tubing....but straight pipes again??? maybe
  6. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    I see straight tubing as part of you and your "brand"
    IMO straight tubing is whats setting your mods apart from the crowd:)
    Keep doing it, innovate it maybe, but keep the core.
    I look forward getting on with my own M8 again, and will be giving you some competition with it:D
  7. kier
    1 Mar 2011
    Thanks p0Pe
    I allready switched to straight :) but don't want to be predictable ;)
    About your M8.....you allready won the competition ;) your M8 is beautifull :jawdrop:
    Wish I had your skills and machines :dremel:
    A little pic of the straight pipes instead of the tubing
    And did some funny things to the mobo tray
  8. Foregasm
    Foregasm What's a Dremel?
    3 Apr 2012
    Don't ever stop with the straight tubing. It's fantastic.
  9. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    Loving this Kier! :thumb:
    And I've always had a soft spot for tilting the mobo backplate!!! Looking damn good! :)
  10. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    Yeah looks good :) Like eye candy :)
  11. bulldogjeff
    2 Mar 2010
    I like the straight tubing better and that tilt looks wicked. all coming along really well. Goan be a monster of a build this is
  12. kier
    1 Mar 2011
    Lol, sorry for the tubing thing. straight it will be ;)
    Thanks :thumb:
    :D
    Thank you Jeff :clap:
    So after some thinking and some urging of fellow modders I decided to do everything straight. It's more work ... but I'm in no hurry;)
    Also a nice idea I have seen in another build is the tilted mobo. Made the back plate again with 2mm aluminum, and marked the shape of the backtray
    Sawing, drilling and Filing
    Placed the original mobo tray, pasted black vinyl again to get it black. Maybe a bit lazy but this is so easy, quick, scratch resistant, inexpensive and just the right color.
    The tilted mobo
    Missing something ... red I think. therefore entirely dismantled the backplate and cut a red plate
    And everything reassembled, this time with countersunk m3 bolts. Rivets are unfortunately too short now
    Nice touch... inside is red now :)
    And placed it. Now with some daylight pics
    Placed NorthQ fans in front instead of the Turbine masters
    And received some nice red hardware
    An made an additional air outlet​​. Will place mesh later.
    Furthermore beeing busy with the acrylic pipe, to get this as straight as possible. Just like the other side, cut a piece of aluminum with fanhole
    Made it black and cut and placed a piece of red acrylic. Placed a loose tube for size and see if it's straight
    And fits nicely along the mobo tray
    And the weekend is over ... unfortunately. More Next week ;)
  13. tobyak
    tobyak What's a Dremel?
    5 Jul 2011
    im finding it hard feeling this build, its feeling very same old same old, i love the older projects but this and a few others most notably CM2 dont seem to have any heart to them , just "jobs". the craftsmanship is s ever excelent
    Do you think that it has stoped being a fun hobby and turned in to a 9-5 job?
  14. kier
    1 Mar 2011
    Sorry to hear, Any build that I make is without Compromise and has all of my attention, not just a "job". I want to see for myself what I can do with different cases...and share it :)
    It's definitely still a hobby and is just something I like to do
  15. KiiYzOo
    KiiYzOo What's a Dremel?
    11 Mar 2011
    Looking awesome as always Kier :D
    where can I get the straight tubing? I'd love to use some in my next build :)
  16. samfgr
    samfgr techno : my life
    29 Jun 2011
    looking great like all your mods I saw :) i'm looking foward to the rest of it :)
  17. kier
    1 Mar 2011
    I've bought it at http://www.bouwplastics.nl
    Thanks bro :thumb::thumb::thumb:
    And thank you Bit-tech for the nomination....again :clap::clap::clap:
  18. Foregasm
    3 Apr 2012
    I VOTE KIER.
  19. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    Damn thats some nice tubing you used there, I always wanted to try it but I'm a little offset by the price of all the fittings :)
    What fittings did you use? Quick SLI connectors to plug the arcyl pipes into?
  20. Pranja
    Pranja Blackwolf
    18 Dec 2011
    This looks great. I love the way you mixed red and black plexi.
