Case Mod - In Progress CaseLabs MAGNUM M8K
Discussion in 'Project Logs' started by kier, 18 Mar 2012.
  1. craig - toyoracer
    craig - toyoracer Member
    1 Mar 2011
    Oh man, late to the show, and soooooo much done already. Double the size for twice the fun. :thumb:
    Very nice ideas and work done to date. Really expanding on the layered look with this one, very nice.
    Keep up the wonderful work my friend. :clap:
  2. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Awesome. I was right about the tubes. Straight looks muuuch better. ;)
  3. jeckulz
    jeckulz New Member
    18 Jan 2011
    I cant believe you spent that much on a case then started cutting it to bits.
    Ballsy.
    Subbed
  4. Phyonics
    Phyonics New Member
    4 Oct 2011
    Stubbed! Looks excellent so far :)
  5. kenco_uk
    28 Nov 2003
    I don't know if it was intentional when you took the pic and I hope you don't mind me nabbing part of it for my av, but I thought it was very cute!
    This is looking very tasty. Pin sharp and precise. Nice one, kier :thumb:
    Edit: Also, I love the kit!
    But where can I buy one from? Everywhere I look are out of stock :( I ordered a load of white sleeving not too long ago with the idea of sleeving every last cable in my rig but I'm struggling to find a set of tools to help me do the job.
  6. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    How did I not see this before :sigh:
    Going by your last build I know that this is going to amazing and it really is looking amazing already.
    Sub'd :thumb:
  7. Mattmc91
    Mattmc91 Well-Known Member
    18 Oct 2009
    How's your toe feeling?
    Great build so far :)
  8. HybridCore
    HybridCore Member
    20 May 2011
    Nice to see other forums with this case on it too. Jim (CaseLabs) did a great job with the case and has great support, on Overclock.net and through the website.
    Nice job on the build so far. If you do care, I believe the USB 3.0 header for the Magnum cases have been released. I don't remember exactly. I'll have to go check the thread over at OCN. Enjoy your case. :)
    Edit: And subbed.
  9. kier
    kier -----------------
    1 Mar 2011
    Thanks Damien :clap:
    :D
    Jim certainly did a great job, and is a great person. it's been a while since I updated this log.
    but I didnt sit still ;) finally have some great new hardware for this build. 2x GTX680 and all waterblocks will be the new EKWB CSQ design
  10. HybridCore
    HybridCore Member
    20 May 2011
    Pictures!
    We (OCN + CaseLabs) are working on a mid-tower case right now. You should be able to see the prototypes at the CaseLabs section of OCN. Hopefully it will turn out great like the other cases. You can go there and contribute by posting what you want in the case (remember, we're still at prototypes). There's been a boat load of stuff posted already. We'll see what Jim can come up with. :)
  11. kier
    1 Mar 2011
    EKWB Sponsor update!!!
    Received this week a great package from EKWB. Again my thanks to Gregor and everyone from EKWB that makes this possible. All beautiful products for CaseLabs build
    The EK-Supremacy - Nickel
    The EK-FC680 GTX Backplate - Black CSQ
    EK-FC680 GTX - Acetal + Nickel CSQ
    EK-Multioption RES X2 - 250 Advanced
    2x EK-CoolStream RAD XT (360)
    2x EK-CoolStream RAD XT (240)
    A EK-DDC Dual TOP V.2 G1/4 - Black Acetal
    Some beautiful EK-PSC Fitting 13mm - G1/4 Black
    And some EK-PSC Adapter 90° G1/4 Black
    And EK-PSC Adapter 45° G1/4 Black
  12. kenco_uk
    28 Nov 2003
    Wow, those plexi tops look gorgeous.
  13. The boy 4rm oz
    10 Apr 2008
    Congrats on the new gear.
    I really like some of the new EK CSQ gear. I ordered some in at work to take a look and I was quite impressed. The design isn't for everyone and it is a shame that they have discontinued the Supreme HF blocks because now I will need to buy the 30% more expensive and less visually appealing (for me anyway) Supremacy block instead while gaining marginable performance improvements.
  14. HybridCore
    HybridCore Member
    20 May 2011
    I don't really get the new design but it still looks nice. Hopefully they've fixed the nickel plating problems by now. The EN blocks have a problem with staining.
  15. kier
    1 Mar 2011
    Update!!!
    It has been a while, but here a big big update
    First a thank you note for Sicomputers. The GPUs (GTX680) were not available, but thanks to the good and fast service from Sicomputers I got 2 beautiful cards.
    And as promised an honorable mention with banner ;)
    2 beautiful GTX cards
    First tested on air
    Time to give the cards a transformation
    And the great EK-FC680 GTX Backplate - Black CSQ
    Also placed the EK-Supremacy - Nickel
    One GPU placed
    For now with multi link, but will not use these in this build.
    Really like the backplate.
    Placed 2e GPU
    Allready installed the radiators with theNorthQ fans
    With the EK-CoolStream 360 RAD XT
    And then I received a great package from....van Freddy.... Highflow
    With (hope so) the latest products that I need for this build.
    Offcourse with some Fillports
    And 15mm extenders
    90 degrees adapters
    Smaller extenders
    Because I've made the angle in the mobo tray, the 45 degrees rotery's will not fit. Therefore I've ordered some 30 degrees rotery's
    and offcourse my favorite adapter, the multi link adapter
    I still have some other ideas for the Case labs case, but for this I'll need some more acrylic. Therefore 3mm transparent
    And UV red acrylic
    Freddy/ Highflow thank you again for the quick service and good products and ... have a great holiday.
    Now the explanation why this order has taken place. I'll will make this setup with the solid tubes
    From the CPU, 2 pipes going up. Because there's an angle in the mobo I can not use the 45 degree fitting to connect on a fillport
    That's why I'm using the 30 degrees rotery
    Ordered the extenders to lower the in- and outlet.
    To create a corner with the acrylic tubes I use the 15mm extender, 2x multi link and the 90 graden adapter
    Now only a multi link, later there will be added a fillport
    More multi links
    And connected everything
    Chapter red acrylic :)
    Previously I had a 5mm thick transparent plate between the case and the pedestal. But I want the red lines run entirely in this build, therefore changed the middle part.
    The red acryl.
    Cut it.
    After this cut the 3 mm transparent transparant acryl "]acrylic[/URL]
    Placed like this.
    Removed the plastic.
    The plate is transparent to get a free sight what happens in the pedestal.
    I was not very happy with the front, just didn't like it. Therefore I've sawn a new piece of red acrylic
    With the sizes of the detachable front.
    Used some spacers.
    Also sawn a new plate with the fanholes and the holes for the Lamptron switches
    With illuminated edges
    The 2 spaces above the HDD coolers are for the Lamptron controllers
    The last thing i've did is sleeving the Coolermaster 1500w Silent pro M2
    Finished
    24 pins
    CPU cables
    And some GPU cables
    Connected everything to see how it looks.
    That's it for now...Grtz. :rock:
  16. The boy 4rm oz
    10 Apr 2008
    I know people will complain about using so many angle and bulkhead fittings but who cares, it looks awesome and the plumbing will definitely end up being a feature, just how I like it :D. Looking great so far my friend.
  17. whyte
    whyte New Member
    27 Mar 2012
    Gorgeous as always. Huge fan of the changes to the front. :thumb:
  18. Hanoken
    Hanoken O.O
    12 Jul 2012
    Good thing I'm no where near this.... because I'm drooling so much over the final pic :eek: that there is enough to fill your whole cooling setup with it ( gross I know but I couldnt find any other way to put it XD) just when I thought it couldn't get better, you had to amaze me yet again ^^ keep up the brilliant work! :)
  19. bulldogjeff
    2 Mar 2010
    ShIIIIIt !!!!! those W/C blocks are so sexy.. all coming along very nicely indeed.
    Carrie likes this.
  20. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    What,,, Kier.... and this case.... now thats what i call epic build. Looks so nice, loving the circular pattern watercooling gear, too late im sure but that would have looked so sweet themed into the case mod more, but what you do is always top notch. cant wait for more.
