Case Mod - In Progress Caselabs SMA8 - Monochrome
Discussion in 'Project Logs' started by flix, 30 Jul 2015.
  1. flix
    flix Minimodder
    5 Aug 2009
    Hello again,
    I'm actually working on a second project.
    I will mod a Caselabs SMA8, it is a dream case for me since I've seen it. :)
    There is not that much to say about the case, except that it is one of the biggest and priciest cases on the market.
    The qualitiy of it is a dream.
    concept:
    hardware:
    CPU: Intel 5930K
    Mobo
    : Asus X99 WS-E
    memory: memory: 32GB Klevv Cras 2133Mhz
    VGA: EVGA GeForce GTX 980 Ti Superclocked+ ACX 2.0+
    Powersupply: EVGA SuperNOVA P2 1200 1200W ATX 2.3
    Storage: t.b.a.
    watercooling:
    CPU Block: EK-Supremacy EVO
    VGA Block: EK-FC XXX
    pumps: 4x Alphacool VPP 655 PWM
    reservoir: custom
    tubing: hard tubing
    fans: Noiseblocker Black Silent PL1, PL2 & PK2
    fan control: Aquaero 5lt
    The case:
    I've chosen Gunmetal Grey, I think its the best looking Caselabs color.
    You can easy remove the tray, I like this option a lot.
    Enough space for two power supplies :cool:
    a lot of room for hardware. :)
    I will use a 560er and 280er radiator in the bottom section.
    In the Front would be enough room for another radiator but i will just mount fans there.
    Backside:
    I love that case!
    Big thanks to:
    I'm very happy for supporting this project. GamingRigs is an official Caselabs Reseller in europe.
    They support this project with some nice Black Silent fans.
    [​IMG].
    He builds awesome custom parts. This project is get an awesome slight.
    A big thanks also goes out to ModdingStylez, he provides some nice sleeved cables. Check out his Facebook Page, there you can win 1 out of 3 custom cases.
    They support this project with some nice parts for sleeving, thank you.
    Thank you for a nice discount
    Thank for supporting this project with some nice waterblocks and liquid.
    Thank for supporting this project with this awesome memory.
  2. Jeffinslaw
    Jeffinslaw What's a Dremel?
    26 Jun 2014
    Will be interesting to see what you do with all that space! I'll follow along to see more.
    -Jeffinslaw
  3. pre
    pre Minimodder
    24 May 2004
    Great case from a great manufacturer.
  4. flix
    flix Minimodder
    5 Aug 2009
    There is still not enoug space for what I want to do. ^^
    Yes, absolutly
    One of the highlights for this build arrived yesterday.
    What could it be?
    Its an sLight made by Martmamod/Stempel-Hauser.
    Great company with nice service and high quality products.
    On all pictures is an protectie sheet on the slight but it looks great anyway.
    fits very well. :) (not the final graphics cards.)
    this equal distribution of light :thumb:
  5. Farsan
    Farsan What's a Dremel?
    1 May 2014
    Why are you using 4 pumps?
    I am waiting to see it going :thumb:
    PD: You posted while i was :duh:
  6. flix
    flix Minimodder
    5 Aug 2009
    hehe :)
    Why not 4 pumps? :p
  7. flix
    flix Minimodder
    5 Aug 2009
    I'm very happy for being supported by Noiseblocker.
    They sent me 8x PL1, 1x PL2, 6x PK2 fans. They look so fantastic in this case.
    Thanks for supporting me. :)
    The package includes a lot of accessories. its to bad that the decoupling rubber seals doesnt fit with m4 screws which are needed for the radiators.
    The hardwarelabs GTS 560:
    Fans and radiators:
    The black screws are still missing, I hope I get them soon. :)
  8. Jeffinslaw
    26 Jun 2014
    I didn't know they did custom sLights! Well that will come in handy for a future build :D
    -Jeffinslaw
  9. flix
    flix Minimodder
    5 Aug 2009
  10. flix
    flix Minimodder
    5 Aug 2009
    I will continue this mod in the nex few weeks. :)
    Here is a small teaser of what will fellow:
    We will see if this will work. :)
  11. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Nice project.
  12. flix
    flix Minimodder
    5 Aug 2009
    Thank you. :)
    Update
    Moddingstylez
    supports this project with some amazing custom cables.
    Thank you for that.
  13. flix
    flix Minimodder
    5 Aug 2009
    The last days I've prepared the radiators.
    original state:
    Cleaned them, sleeved them and change the screws. Looks much better, dont you think?
  14. flix
    flix Minimodder
    5 Aug 2009
    small update:
    I've cleaned the pumps.
    Changed the fittings from Bitspower to Barrow.
    original state:
    New fittings, later I exchanged the green o-rings for black ones.
    Besides that, I used some new screws. :)
    the result:
  15. hovek
    hovek “Can’t or won’t?” Sterling Archer
    23 Jan 2014
    First of all... my favourite case! Will watch.
    Second, are those barrows just like bits power quality wise? I was looking at them but don't know much.
  16. flix
    flix Minimodder
    5 Aug 2009
    Yes, the SMA8 is just awesome.
    I have a lot of Bitspower fittings and now some from Barrow, I think the quality is pretty much the same. ;)
    Update:
    Some new shots of the hardware.
    The motherboard of my dreams. :) Asus X99 WS-E
    Mounted it to the tray of the Caselabs SMA8. :)
    Mounted the waterblocks of the 980Tis and CPU:
    First try of the tubing, what do you think?
    I tried to avoid the bend the other way round...
  17. bundymania
    bundymania Bastelorakel Industries Worldwide
    4 Jun 2009
    I like the "cleaned" pump
    Do the same with the EK stickers :)
  18. flix
    flix Minimodder
    5 Aug 2009
    Good idea with the EK stickers.
    I continued in designing the "waterplate". Its nearly finished, it can be milled very soon.
    I hope it will fit. :D
  19. flix
    flix Minimodder
    5 Aug 2009
    I've printed a 1:1 sketch of the waterplate.
    Here is how it will look:
  20. eucalyptus
    eucalyptus I am 19 and Swedish!
    29 Sep 2015
    Waaaait a sec here, do I see FOUR D5 pumps???????????? WOW :D :D :D :D :D What in the power of God are you going to run with them? :D
    I understand though it might be for aesthetical purpose, but still, wow :D
    Anyway, I like what I see :dremel: :dremel: :cooldude: ;)
