Case Mod - Complete ⭐ Casemod Chapolin Colorado. "They did not count on my cunning!" Follow me the Bons.
Discussion in 'Project Logs' started by douglas alves, 21 Jan 2019.
  1. douglas alves
    douglas alves Minimodder
    3 Mar 2014
    Contruí PSU cover in a different designer to show the source.
    Some lines with designer to match with every project.
    It all started with a simple cardboard box.
    _Prometheus_ likes this.
  2. douglas alves
    3 Mar 2014
    I created 2 piece in acrylic, following the same designer of the other pieces, in which will be part of the internal and external finish of the cabinet.
  3. douglas alves
    3 Mar 2014
    Next piece made in acrylic, is the finish of the motherboard chassis.
  4. douglas alves
    3 Mar 2014
    I used a 5-pelegas LCD screen with HDMI, and the power used is a USB cable.
    I had to adapt both the front cover of the cabinet and the screen itself.
    And every finish following the same designer of the other pieces of acrylics
    [​IMG] [​IMG]
  5. douglas alves
    3 Mar 2014
    Continuing
  6. kim
    kim hardware addict
    10 Jan 2016
    what you manage to do with hand tools and plastic is a real source of inspiration
    douglas alves likes this.
  7. douglas alves
    3 Mar 2014
    Thank you.
    Tools for me, are limited, I only have them to work with, I even like it all the way and I pride myself after everything is ready.
    In the end the result comes out satisfactory.
  8. douglas alves
    3 Mar 2014
    Stage of painting.
    Ink Spray
  9. douglas alves
    3 Mar 2014
    All the pieces made in acrylic and all with finish.
    All parts made manually. Using only saw Tico-Tico and Micro Rectifica.
    Finishing with files, sanding and polishing with polishing dough and flannel.
    satisfactory result.
  10. douglas alves
    3 Mar 2014
    Continuando
  11. Vault-Tec
    30 Aug 2015
    It's incredible, I love it. It almost looks surreal, like a cartoon.
    Amazing work man !
  12. douglas alves
    3 Mar 2014
    Thank you very much
    I love making casemod.
    Here in Brazil things are difficult. I dedicate a lot to modding.
    Thanks for liking it.
    Vault-Tec likes this.
  13. douglas alves
    3 Mar 2014
    Assembly and some things made to complement the casemod.
  14. douglas alves
    3 Mar 2014
    Test of the part of the shell made in acrylic in the shape of the heart.
  15. douglas alves
    3 Mar 2014
    Black playte para vga. Casemod Chapolin.
  16. douglas alves
    3 Mar 2014
    External finishing
  17. douglas alves
    3 Mar 2014
  18. douglas alves
    3 Mar 2014
  19. douglas alves
    3 Mar 2014
  20. douglas alves
    3 Mar 2014
