Scratch Build – In Progress CaseMod: TARDIS - FINISHED!!!
Discussion in 'Project Logs' started by Pfaffen, 19 Aug 2012.
  1. Pfaffen
    Pfaffen What's a Dremel?
    18 Mar 2007
    Well at the request of a good friend, I have decided to build a 1/4 scale CaseMod of the Newbery TARDIS.
    What is a TARDIS and what is a Newbery TARDIS... Well... I'm sorry, but you must be new to Science Fiction!!! TARDIS is an acronym and stands for Time And Relative Dimension In Space and is the cornerstone of the Dr. Who series.
    The Newbery TARDIS is the TARDIS created by Barry Newbery for Season 14 and was used until Season 18. Thank you to http://www.themindrobber.co.uk/tardis-police-box.html for an extensive look at the four decades of TARDISs.
    This is the one we will be building for my friend in Australia.:clap:
    YEHBABY likes this.
  2. Pfaffen
    18 Mar 2007
    This CaseMod will be a little different from the others. It is being built to house an Asrock Ion 330.
    Here are some shots of the prototype in foam board. Both of the TARDIS and the Ion 330.
    YEHBABY likes this.
  3. Pfaffen
    18 Mar 2007
    For those who wanted to know:
    THE BRACKACKI BOX (1963-1976)
    THE BARRY NEWBERY BOX (1977-1980)
    THE TOM YARDLEY-JONES BOX - Mk I & II (1981-1989)
    THE RICHARD HUDOLIN BOX (1996)
    THE EDWARD THOMAS BOX (2005-)
  4. Balder
    Balder Calmer than a monk on morphine
    4 Jul 2003
    as a new fan of Dr Who (that is I started watching with the 2005 season) this is a must to follow!
  5. Pfaffen
    18 Mar 2007
    Starting out simple, here is the base. I found it very worthwhile to draw 1:1 on the base. The corner marks are visible
    Here is a closeup. It shows the swing of the door.
    YEHBABY likes this.
  6. TekLord
    TekLord Tek by Design
    7 Jan 2012
    You had me at TARDIS.
  7. Steve_of_Death
    Steve_of_Death What's a Dremel?
    3 Jun 2012
    I look forward to seeing this completed
  8. Pranja
    Pranja Blackwolf
    18 Dec 2011
    After it is finished,you can put a cat dressed as a Dr. Who inside.
    Just kidding, great build, can't wait to see more. ;)
  9. Pfaffen
    18 Mar 2007
    So, we start with the doors.
    I am using hard maple for the case. You'll also see some MDF (base and roof) as well as some other thin plywoods.
    Second and third pass through the planer.
    Now that all the faces are flat and smothe time to cut to rough length. 3 panels should do it.
    The TARDIS has four side and each side has two doors. Well then that is 16 stiles and.... some extra.
    Voila!
    Now for some rabbets!
    and now for the rails, well 9 of them. They will all be cut in half to make 16 rails.
  10. Pfaffen
    18 Mar 2007
  11. Pfaffen
    18 Mar 2007
    Now to cut the tenons on the rails. I build the jig because I did not want my fingers that close to the blade. (I had an issue back on the WorldMap build) cut my left index finger on the tablesaw with a plexiglass blade. Eight stitches if I remember correctly.
    Here you can see some of the finished ones and those with the shoulders cut.
    Here they are all stacked up.
  12. whatsthatnoise
    whatsthatnoise What's a Dremel?
    21 Mar 2012
    Good idea for a case. Make sure it's as indestructible as the real deal! :thumb:
  13. Pfaffen
    18 Mar 2007
    GREAT!!! Welcome to the Dr. Who family!!
  14. Cheapskate
    13 May 2007
    COOL! but can you bring yourself to paint that lovely wood?
    ...Blue stain maybe?
  15. Pfaffen
    18 Mar 2007
    Cheapskate, somethings require sacrifice. :)
    I'm sure I can find some blue dye... maybe I should try that out.
  16. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    I would agree... why use hard maple if you're just going to paint it?
    I think when I was looking at TransTint dyes for something, I remember seeing a blue... I'll see if I can find it. (Though I don't know where you are)
    Edit: http://www.homesteadfinishingproducts.com/htdocs/TransTint.htm Has an example down the page a little ways
  17. Pfaffen
    18 Mar 2007
    Sorry,
    The reason for the hard maple is because I have alot of it. I bought about $100 worth of it 2 years ago and it has sat in my shop. The project I wanted it for didn't happen. So... why not.
    Before I planed it, I thought of buidling then entire thing out of wood and then use a clear finish and make it a "Wooden" TARDIS, but then, after a quick conversation. Decided to go with the traditional Blue.
  18. Pfaffen
    18 Mar 2007
    On to the bevel on the doors.
    I used a 45' mitre bit to carve out the bevel on the rails and stiles. I established the start cut and end cut lines and cut to them.
    Here are all 8 doors dry-fitted.
    Still have the corners to clean up. I'll carefully have to cut with the rail angle and then the stile angle. A little at a time.
    YEHBABY likes this.
  19. Pfaffen
    18 Mar 2007
    Here is the jig to hold the doors in place.
    Door in place.
    Corner cleaned up.
  20. Pfaffen
    18 Mar 2007
    Here are the cross pieces on the doors. Best if I show them in sequence.
