Modding CaseModBlog.com Update Thread
Discussion in 'Modding' started by mnpctech, 27 Sep 2010.
  1. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    I'll have to tell Derek you said that, hes a fan of Mod Men :cooldude:
  2. mnpctech
    21 Apr 2003
  3. mnpctech
    21 Apr 2003
  4. bulldogjeff
    2 Mar 2010
  5. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    nice to see an air-cooled case mod for a change
  6. mnpctech
    21 Apr 2003
    Agreed. I can still appreciate a nice air cool system :thumb:
  7. mnpctech
    21 Apr 2003
  8. Cheapskate
    13 May 2007
    Oh, Lord...
    Eel had a lot of fun with the monkey noise.
  9. mnpctech
    21 Apr 2003
    yeah, It's great :D
  10. Cheapskate
    13 May 2007
    Just listened to EP#2. Kyle had a lot of fun with the monkey jokes.
  11. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    you know it...
  12. mnpctech
    21 Apr 2003
    Fractal-Design’s new Define R4 allows you to mount a 2x 120mm (240mm) Radiator in it’s front 2x 140mm cooling fan module. I discovered that it will also fit a 2 x140mm (280mm) with some minor modifications! Here are the steps involved with modifying the Define R4 to fit any manufacturer brand or model 2 x140mm (280mm) Radiator in the front.
    http://www.mnpctech.com/casemodblog...idator-in-fractal-design-define-r4-mid-tower/
  13. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Bill has another Fractal case.
    I think we will see another epic mod. :D
  14. Guest-23315
    Guest-23315 Guest
    Enjoying the new podcast Bill, good to have it back, albeit in a different frock :lol:
  15. mnpctech
    21 Apr 2003
    @Pranja, Indeed! :D
    @Mankz, we're lovin it, and lookin forward to Cheap's return!
  16. mnpctech
    21 Apr 2003
    btw, I'm currently customizing several Define R4s.
    Contrary to what some reviewers have told people, The Define R4 will fit a Corsair H100 radiator in the top panel, however it will depend upon DDR slots and north/south/mosfet heatsink locations on some motherboard models. If you discover these elements are obstructing your 240 radiator install, You can do 2 things in the Define R4 to gain extra space for your 240 radiator install.
    1. Offset 240 radiator toward the left side of the top panel, by locating the radiator to the outer screw mounting holes used by optional 140mm fans in the top panel. There will be openings for all of the radiator mounting screws in the factory honeycomb perforations.
    2. Option 1. didn't buy you enough space? Then you can drill 4 additional radiator screw mounting holes toward left side of the top panel, to offset the 240 radiator even further, to clear any obstructions created by some motherboards.
    Hope this Helps!
  17. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Here we go. :D
  18. Kylevdm
    4 Oct 2007
    haha, different frock is one way to put it... We have our first guest in EP3 which is being recorded on Sunday night.
  19. Guest-23315
    Guest-23315 Guest
    I begrudgingly accept your invitation, many thanks.
    :lol:
  20. Kylevdm
    4 Oct 2007
    give us a few more episodes, I have a few things planned to allow people to be more actively involved :D
